Where are my horns located? - JeepForum.com
post #1 of 12 Old 01-25-2016, 11:28 AM Thread Starter
02Lightning
My horns quit working on my ZJ, I popped the hood real quick to take a peak and didn't see them. Where are they located, so I can work back from there?
1995 Jeep Grand Cherokee Limited 4.0L NP249 Transfer Case, 42RE, 212,000 miles
02Lightning is offline
post #2 of 12 Old 01-25-2016, 11:33 AM
jrobeson18
Yard Mechanic
jrobeson18's Avatar
Im curious as well, im wanting to change mine. i have access to MotoLogic (like alldata). ill take a quick look to see where they are.
jrobeson18 is offline
post #3 of 12 Old 01-25-2016, 11:35 AM
kg6mov
Hears the voices
kg6mov's Avatar
They are behind the front crossmember under the passenger side headlight (but not accessible from the headlight). You may be able to get to them by reaching up in the bumper on that side.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ 5.9 - Junked
kg6mov is offline
post #4 of 12 Old 01-25-2016, 11:36 AM Thread Starter
02Lightning
Thanks, I can hear the relays clicking under the dash, so the problem must be between the relays to the horns.
post #5 of 12 Old 01-25-2016, 11:37 AM
jrobeson18
Yard Mechanic
jrobeson18's Avatar
My 97 zj show the horns to be located under the radiator. behind the lower splash shield.
post #6 of 12 Old 01-25-2016, 11:46 AM
JonS
They are actually under the battery - accessible from below. Often the wire leads go bad and you need to make new ones like this:
http://www.jeepforum.com/forum/f13/early-signs-pcm-failure-3606481/
JonS is offline
post #7 of 12 Old 01-25-2016, 03:21 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Mine are on top o my head.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
Originally Posted by HighLonesome
coralman is offline
post #8 of 12 Old 01-25-2016, 07:25 PM
JaimeZX
Yup. Lie on your back under the front bumper and look up under the headlight/battery. I think it's a 13mm nut to take them down.
I got this thing to replace my low note, pretty dang loud. And cheap.
http://www.amazon.com/gp/product/B00...ilpage_o05_s00
HID Projector retro! http://www.jeepforum.com/forum/f13/hid-projector-retrofit-build-thread-3082289/
JaimeZX is offline
post #9 of 12 Old 01-25-2016, 08:00 PM
Buick350X
I have the same clicking, yet the alarm will make the horns, honk???
1995 Jeep Grand Cherokee Orvis 4.0L Up-Country + BB facebook.com/groups/JeepOrvis/ or JeepOrvis.club
Buick350X is offline
post #10 of 12 Old 01-25-2016, 08:28 PM
kg6mov
Hears the voices
kg6mov's Avatar
The alarm is on a separate relay from the normal horn relay IIRC.
kg6mov is offline
post #11 of 12 Old 01-26-2016, 12:15 AM
Uniblurb
Uniblurb's Avatar
Speaking of relays, if you're hearing a relay under the dash clicking when pushing the horn you may also want to check for a horn relay in the engine compartment PDC. Not sure about the 95 but on my 96 there is a horn relay in the PDC and try flipping it with another one like AC if it works.
Believe the bracket which holds the 2 horns may also be part of the horn ground system. Check where the bracket makes contact with the other metal which believe only has one screw in it.
Uniblurb is offline
post #12 of 12 Old 04-03-2016, 07:46 PM Thread Starter
02Lightning
Ended up doing what Johns did. Thx
