Where is the mileage stored? - JeepForum.com
post #1 of 12 Old 07-18-2006, 10:21 AM Thread Starter
WolfgangK
Does anybody know in which component the mileage of a WJ is stored?
If I swap the instrument cluster, will it then show the mileage of the donor car or of my car?
What component do I have to swap if I want to change the mileage value shown on the display on the odometer (don't worry, I do not want to cheat an unaware buyer)?
WolfgangK is offline
post #2 of 12 Old 07-18-2006, 10:35 AM
nierace
nierace's Avatar
2003 WJ
Ever see ferris bueler's day off ?
I think it should show your cars, if thats the one thats getting the new cluster, I dont think the counter comes out? But the computer will also have the mileage stored there, that is where the dealer checks the mileage.
nierace is offline
post #3 of 12 Old 07-18-2006, 10:58 AM
241comp
The mileage is stored in the cluster, PCM and BCM I believe. You may have problems if you put in a PCM in that doesn't match the cluster or BCM's stored mileage but I don't believe you'll have trouble the other way around (though the cluster may display the PCM's mileage instead of it's own?).
edit: I read your disclaimer but keep in mind that while you may have reasons for changing the displayed mileage now, if you were to sell the car years from now and forget to tell the buyer about the mileage change, you could get in serious trouble.
'09 XK Ltd - 5.7L, QDII, OME HD
(retired) '99 WJ Ltd - 4.7L, QT, Upcountry
241comp is offline
post #4 of 12 Old 07-18-2006, 11:20 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Mileage is with the cluster.
Swapping in a different cluster will cause the odometer to read what is on the cluster, not the actual mileage on the Jeep.
Wheelin98TJ is offline
post #5 of 12 Old 07-18-2006, 11:33 AM Thread Starter
WolfgangK
@241comp: I understand your concerns, but don't worry, I will not sell the car with an altered mileage.
For some customs reasons I need somebody to determine the value of the car. More miles -> less value -> lower payments (not the other way round as it it sometimes done). I need more miles for a few mins only.....
post #6 of 12 Old 07-18-2006, 11:52 AM
///BHRpowered
///BHRpowered's Avatar
I don't think its stored in the cluster. another thread went off-topic and it was discussed when I was going to trade an 02-04 with 02grands 00.
The cluster should be dependent upon both the ecu and another set of fail safes. otherwise it would be to easy to commite odometer fraud
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #7 of 12 Old 07-18-2006, 11:53 AM
rm2001wj
rm2001wj's Avatar
The IC does store a mileage number (and most likely the PCM and BCM do as well). The WJ FSM says that with the "proper inputs" that number can be increased but not decreased. If you replace the instrument cluster because of some failure, try to get one with fewer miles than yours so it can be adjusted to read the true mileage.
rm2001wj is offline
post #8 of 12 Old 07-18-2006, 12:23 PM
Wheelin98TJ
JEEP FREAK
I can guarantee mileage follows the cluster.
I temporarily swapped my 02 cluster with my friends 99 and both displayed the cluster mileage.
And odometer fraud is only fraud once you sell the vehicle and claim the mileage is actual. There are countless other ways to reduce mileage on a vehicle that are just as easy, if not easier than swapping out the cluster.
post #9 of 12 Old 07-18-2006, 12:44 PM
///BHRpowered
Apparently you have not lived in VA. every year when you go for inspection they record the mileage, if you have not claimed something through paperwork with the DMV it sends up some sort of red flag, best case is you get a letter in the mail that you must bring the car to DMV and explain, they CAN actually hold your car at the inspection station and have a state trooper impound it if you don't have a reason.
Admin -
post #10 of 12 Old 07-18-2006, 01:10 PM
PumaZJ
do tell.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #11 of 12 Old 07-18-2006, 01:38 PM
241comp
That's good to know. I know that having a PCM and BCM with different mileages will cause problems but apparently as long as they (computers) match, it doesn't matter what the cluster says.
Just be careful - if it is for import duty or something like that, it could be considered tax fraud (I may be wrong - it may be perfectly legal). Of course, IANAL.
241comp is offline
post #12 of 12 Old 07-18-2006, 02:04 PM
///BHRpowered
I thnik that would greatly depend on the country. for about 8 months I have been trying to import a 98 Eunos 800SP, no such question about the mileage has been asked
Admin -
Gas mileage... Robb_ ZJ Grand Cherokee Forum 21 07-12-2009 09:24 PM
better gas mileage for the 5.9l zjnok ZJ Grand Cherokee Forum 38 05-14-2009 04:43 AM
mileage stored on pcm? daman02 ZJ Grand Cherokee Forum 4 08-21-2008 11:33 AM
07 4.7L V8 Getting bad gas mileage sanitarium16 WK Grand Cherokee & XK Commander Forum 19 06-25-2008 09:44 AM
Low Mileage ZJ or High Mileage WJ UofOJeeper ZJ Grand Cherokee Forum 14 06-02-2008 08:30 PM
