Where did you mount your trans cooler? - Page 2 - JeepForum.com
post #16 of 25 Old 05-01-2013, 08:18 PM
StPaul59
Originally Posted by BuzzZJ9er View Post
So I'm trying to get my duck inline to replace my trans and I'm definitely going to put an aux trans cooler in. But how big of one should I get? It does get cold here in the winter but I don't want to have to worry about the trans overheating again.
Also I should probably change filter/ fluid and Adjust the bands. I was told the trans are good if you adjust the bands every 20k miles. Any input would be greatly appreciated.
If I haven't mentioned it yet it is a niner.
I went with a smaller 11x7'' one. I have a clutch fan that sucks a lot of air thru there so I should be fine. I plan to block the air in that spot in the winter time. Its not huge but its better than nothing. Im running the cooler line thru the radiator also.
StPaul59 is offline
post #17 of 25 Old 05-01-2013, 09:35 PM Thread Starter
BuzzZJ9er
Originally Posted by StPaul59
I went went with a smaller 11x7'' one. I have a clutch fan that sucks a lot of air thru there so I should be fine. I plan to block the air in that spot in the winter time. Its not huge but its better than nothing. Im running the cooler line thru the radiator also.
Thank you
BuzzZJ9er is offline
post #18 of 25 Old 05-01-2013, 10:34 PM
StPaul59
http://www.napaonline.com/Catalog/Ca...509_0358469401
This one. At first I mounted it dead center and even with the top of the condenser. Bad idea.. Had to lower it a few inches because the hood latch was hitting it when I went to put everything back together. (I was also doing the Radiator too..)
StPaul59 is offline
post #19 of 25 Old 05-01-2013, 11:30 PM Thread Starter
BuzzZJ9er
Ill have to check the local parts store to see if they can order something like that. I prefer to use them over a big napa chain store.
post #20 of 25 Old 05-02-2013, 08:58 AM
PolkaPower
Mine is 11" x 3/4" thick. I don't think you can fit a bigger one in without cutting some stuff.
PolkaPower is offline
post #21 of 25 Old 05-02-2013, 02:45 PM
StPaul59
11"x11"x3/4" ?
StPaul59 is offline
post #22 of 25 Old 05-02-2013, 02:48 PM
PolkaPower
Originally Posted by StPaul59 View Post
11"x11"x3/4" ?
I'm pretty sure this is the one I got from Oreillys. http://www.amazon.com/Hayden-Automot...ype=automotive
post #23 of 25 Old 06-03-2013, 11:16 PM
StPaul59
I think Im going to replace mine with the one you have. And eliminate the cooler line routing through the trans and widen the gap on the louvers so that heat can escape. I shut the engine off and the temp tends to increase 20-30 degrees whike it sits there. The stupid clutch fan I have isnt as impressive in the warmer weather.
http://www.ebay.com/itm/Automatic-Tr...ad6dc3&vxp=mtr
StPaul59 is offline
post #24 of 25 Old 06-04-2013, 07:10 AM
speedbucket
So this is in addition to the factory cooler right?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #25 of 25 Old 06-04-2013, 11:13 AM
PolkaPower
No. The 98's didn't have a factory cooler. Chrysler felt that the upgrade to the radiator cooler was good enough for some reason. Which is is not.
