where could these bearings have come from? - JeepForum.com
post #1 of 7 Old 07-12-2009, 03:27 PM Thread Starter
jpadilla
2003 WJ
i was on the freeway yesterday when my car started making a low pitched vibrating noise.....so i slowed to about 30 mph then i heard sort of a bang, followed by a ****load of clunks
i pull over on the shoulder and find a trail of large bearings, i look under my car and my trasnfer case is smoking and the area around it is covered in oil.....i drive it home going about 20 mph, clunking all the way
anyway i get home and inspect the undercarriage, my first thoughts(that my transfer case had exploded) were subdued.....my t-case is intact
my front drive shaft has a ****load of play on the t-case end of it.....and im mostly sure thats where the clunking came from......the bearings are between half an inch and 3/4 inch
edit: i recently had my driveshaft remanufactured because one of the seals was messed up(something along those lines)
2003 wj
3" IRO
265/75 16 BGF AT's
jpadilla is offline
post #2 of 7 Old 07-12-2009, 03:54 PM
sdowney717
sounds like your mechanic caused this. Driveshaft had a problem and it grenaded your TC.
sdowney717 is offline
post #3 of 7 Old 07-12-2009, 04:13 PM Thread Starter
jpadilla
2003 WJ
there are bearings on the driveshaft on the tc side...right?(although i installed my own lift kit im a bit of a noob on the innerworkings of the tc/axles and such)
2003 wj
3" IRO
265/75 16 BGF AT's
jpadilla is offline
post #4 of 7 Old 07-12-2009, 04:23 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Is the play in the driveshaft, or the yoke attached to the transfercase?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 7 Old 07-12-2009, 05:06 PM
AgitatedPancake
Those bearings sound big, I'd bet they are from one of your front CV shafts, or if you have a CV front driveshaft it may have exploded...
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #6 of 7 Old 07-12-2009, 05:32 PM
sadass
2x but I lean more toward the CV front driveshaft,
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #7 of 7 Old 07-12-2009, 06:37 PM
elmer_fud
I was thinking a CV shaft to. The CV shafts (and maybe the front axle, but I don't think so) are the only thing with bearings that big
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
hub bearings Inavacuum ZJ Grand Cherokee Forum 24 09-29-2009 02:44 PM
Carrier Bearings or Rear Wheel Bearings? StrokedWJ ZJ Grand Cherokee Forum 4 05-07-2009 01:44 PM
Hub Bearings Inavacuum ZJ Grand Cherokee Forum 1 02-03-2008 06:39 PM
Bearings? cdn96zj ZJ Grand Cherokee Forum 5 06-21-2006 08:01 PM
Hub Bearings & DW ArloGuthroJeep ZJ Grand Cherokee Forum 23 05-25-2006 09:04 PM
