Where can i buy a stock reservoir for a power steering pump ? - JeepForum.com
post #1 of 8 Old 07-06-2013, 12:29 PM Thread Starter
Candymancan
Im sick of these reservoirs from carquest and advance auto... they have cheaply made nipples and they leak crazy.. Im on my 3rd one for my 5.9 and second for the 4.0 I fixed the 4.0 using the old reservoir off my broken 5.9's pump.. So besides a junkyard where can I get a OEM reservoir ?
Candymancan is offline
post #2 of 8 Old 07-06-2013, 02:00 PM
RoldGold
Why not a Dorman reservoir? That's what I have on mine, as the OEM one broke while I was working on the steering gear, and I haven't noticed any leaking. I've been quite pleased with it actually.
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #3 of 8 Old 07-06-2013, 08:15 PM
Oldfrog
2007 WK
I bought an entire pump at a junkyard for $20 or so. Too all of 5 min to remove it. ( yeah, I cut the high pressure line after asking the guy if I could)
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #4 of 8 Old 07-06-2013, 11:24 PM
kachink
I wish I had an answer for that one.
I put a rebuilt pump on about 1-1/2 years ago and it's been leaking at the nipple on the reservoir. I thought it was cracked, but when I took it off it turned out that the nipple was glued on to the reservoir body, not molded in like OEM. Got one from the JY today because I couldn't find a new one for the 5.2.
kachink is offline
post #5 of 8 Old 07-06-2013, 11:25 PM
dnuccio
stealership? probably have to refinance your house for it though
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 8 Old 07-06-2013, 11:50 PM
Oldfrog
2007 WK
I wonder if the plastic nipples on those things can be repaired with some copper tubing and JB weld....hmm..
Oldfrog is offline
post #7 of 8 Old 07-07-2013, 04:20 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
WWW.rock auto.com
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 8 Old 07-07-2013, 06:32 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I guess its just luck of the draw on aftermarket. I got tired of fooling with it after several pumps and resevoir combo's and sprung for the OE pump.
Originally Posted by HighLonesome
coralman is offline
