Where can embed the fuel pressure sensor? - JeepForum.com
post #1 of 14 Old 10-18-2013, 02:55 AM Thread Starter
madelk_RUS
5.2
madelk_RUS is offline
post #2 of 14 Old 10-18-2013, 05:35 AM
newfieZJ
I'd be happy having one under the hood in the engine bay but , left corner on top of the dash would work too . Another place is the VIC . Remove it , cut a plate , mount a few gauges if desired
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 14 Old 10-18-2013, 05:54 AM
ZeeJay1997
is that the actual gauge? if it is a PSI gauge it's not enough. a 40 lb gauge would be suitable.
ZeeJay1997 is offline
post #4 of 14 Old 10-18-2013, 07:20 AM
zjosh93
He's in Russia so I'm guessing that the gauge is in bar. In that case the gauge is a little big, fuel pressure is less than 3 bar so you lose some detail going all the way to 10. Bar seems to be more common in places not-USA. Off hand the only place I consistently see it in car stuff is in MAP sensors.
zjosh93 is offline
post #5 of 14 Old 10-18-2013, 07:51 AM
PolkaPower
I think he is asking where he can tie into the fuel rail to put the sender. You have to put a T in the line someplace. I wouldn't even know where to start except for right where the line has the schrader valve. Gonna be some cutting involved with this one to get that sender in the line.
Why do you need a pressure gauge in the line? Are you running boost or is it stroked?
By the way, St. Peter is an amazing city. I spent a month there about 8 years ago. Can't wait to go back one day.
PolkaPower is online now
post #6 of 14 Old 10-18-2013, 08:57 AM
zjosh93
Right you are Polka. I saw somewhere where a guy took the Schrader valve out and drilled/tapped the fitting for a sender like the OPs. I don't think I would do that to my rail but I guess it works.
zjosh93 is offline
post #7 of 14 Old 10-26-2013, 12:29 AM Thread Starter
madelk_RUS
Sorry that is not what I wrote it attracts a sensor installation)))
I was told the fuel rail has a hole to check the pressure in the system?!
Whether there can be screwed into the sensor?
come to our city! We have very beautiful!
post #8 of 14 Old 10-26-2013, 12:35 AM Thread Starter
madelk_RUS
sports car sensor is screwed into the fuel rail, but they are not standard, and it has a regular place at the fuel pressure sensor
post #9 of 14 Old 10-26-2013, 01:32 AM
dnuccio
you would have to modify the fuel rail to get the sender in there. theres no factory provision for it. there is however a Schrader valve on the driver (i think) side that is used for pressure testing. maybe something could be improvised with that...
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 14 Old 10-26-2013, 11:31 AM
MaintMech
Old and in the way
MaintMech's Avatar
Indeed. You should* be able to unscrew the Schrader valve and install a "TEE" fitting that would allow you to mount the sensor. Most metric pipe threads and US pipe threads are close enough to be compatible.
I might be wrong, if I am please correct me.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #11 of 14 Old 10-26-2013, 12:10 PM
OverlandZJ
Quick search on Google "fuel pressure gauge 5.9L" gave up this link posted by Vermiscus..
Adapter kit for sender to Schrader valve. Summit could most certainly help once the thread is identified on OP's sender. I assume it's a metric.
http://www.summitracing.com/parts/CEI-107133/
OverlandZJ is offline
post #12 of 14 Old 10-26-2013, 02:10 PM
zjosh93
http://blog.hemmings.com/index.php/2...re/#more-11621
Found this. Not the post I was searching for but it works.
zjosh93 is offline
post #13 of 14 Old 10-27-2013, 11:39 AM Thread Starter
madelk_RUS
and the thread -4 exactly go with my valve?
post #14 of 14 Old 10-27-2013, 12:11 PM
OverlandZJ
You need to identify the thread on your sending unit shown in picture above..
