when i turn and make u turns - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > when i turn and make u turns
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 04-06-2004, 12:14 AM   #1
djhart183
when i turn and make u turns my jeep jerks really bad and it dosnt turn smooth at all. it takes like 30 sec to make a u turn this dosnt sound healthy at all i love my jeep but im kinda of tempted to drive it off a cliff.
djhart183 is offline   Reply With Quote
Unread 04-06-2004, 06:26 AM   #2
greasefingers
1994 ZJ
Mine did that, I ended up having to replace the transfer case
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 04-06-2004, 06:36 AM   #3
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
djhart,
I'm guessing that you have the quadratrac. You may have a bad viscous coupler. If so, you'll need to replace it.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 04-06-2004, 02:59 PM   #4
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
is it like a binding noise maybe diff problems.
walter_da_jpr is offline   Reply With Quote
Unread 04-06-2004, 04:25 PM   #5
MaineZJ
Does it feel like you're driving a part time 4wd system? Only happen after you've driven a while?
Might be the vicous coupler in the transfer case is failing and locking up. Makes it hard to turn, lots of tire scrubbing and maybe some hopping.
93 ZJ
MaineZJ is offline   Reply With Quote
Unread 04-06-2004, 04:31 PM   #6
greasefingers
1994 ZJ
Well I had both replaced and here were my symptoms: the front differential howled like my cat in heat. This noise only occurred under a load…driving not coasting. It cost me just over $ 500 for the dealer to do. My 94GC has Quadratrac hence the NP249 transfer case. When I would turn sharp 90 ° at slow speeds, as one would while parking, the front wheels would turn at a much different rate than the rear wheels. This causes the jeep to shimmy, buck, and skip the front tires. The bucking was loud enough to be heard from the outside of the vehicle. I know this because people would stare at my GC as I would try to park it. The viscous coupling was shot. This over $ 1,000 for the dealer to install. By the way, I have only taken my jeep to the dealer three times because rate is $ 80/hr. Also I don’t to transmissions, TC’s,or Diff’s. Oh did I mention that it was $ 1,800 for them to replace the trans. Parts on my GC that I have physically replaced myself: fuel pump, radiator, brakes, shocks, water pump, tune-ups, & exhaust systems including my cat which rattled to the point that it drove me crazy. But I still love her
Cheers Steve
Unread 04-06-2004, 04:45 PM   #7
beanplant
I jsut fixed this on mine... First the guy said my spider gears were bad... replaced them, $600.... Did the SAME thing afterwards, then replaced the clutches in the transfer case ($400.) I would try to get a quote on getting the transfer case clutches replaced. Now mine drives like a dream again. I jsut got it back last week.
beanplant is offline   Reply With Quote
Unread 04-06-2004, 05:42 PM   #8
MaineZJ
Depending on the year of your jeep, if it is your transfer case- it might be cheaper to swap in a 242 or a 231 in place of the 249
93 ZJ
Unread 04-06-2004, 07:52 PM   #9
Swamp Boy
I would just swap in a 242 ... Its a better case and you will have 2 wd after that...
Here is a link to my write up in case you decide to tackle it...
242 Swap..
Just another soccer moms Grocery getter....
[Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url]
Swamp Boy is offline   Reply With Quote
Unread 04-06-2004, 09:01 PM   #10
Bob K
I don't know how bad your problem has gotten. But I read a post by a guy who fixed that problem by changing his fluids and strictly adgering to Daimler's recommendations on fluids. These easy fixes usually aren't enough...but somtimes they are.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline   Reply With Quote
Unread 04-06-2004, 09:02 PM   #11
Bob K
I don't know how bad your problem has gotten. But I read a post by a guy who fixed that problem by changing his fluids and strictly adgering to Daimler's recommendations on fluids. These easy fixes usually aren't enough...but sometimes they are.
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Unread 04-06-2004, 09:15 PM   #12
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If there is a cottman transmission place nearby, take it there and tell them that you think that your VC is going out. They will check it for FREE>
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
