#1 | |
Wheels and Tires
ok so now ive got the lift ordered, 6.5 IRO LA, i think im pretty set on what performance parts im getting, im pretty sure im gonna go with iceland winch bumper and fender flares, but id like the jeep to have a good wide stance, i was probably gonna go with either pro comp tires or bf goodrich, but im not exactly sure what would be the best size cause from ive read 32's are the max wheel to use with the quadra trac system, is that true or false?? im not really sure what wheels to go with, i could always use my stock wheels i guess but i was thinking id like to go with something different, i dont really wanna go with black id like to go with maybe chrome or something but not really sure where to look for them at, i dont want anything thats too overkill thats looks like it should be on a benz or something, i kinda like the mickey thompson classic wheels but a friend of mine thats in the tire and wheel business says they wouldnt work cause of the....offset, i think thats what he said but i dont really remember now, i tend to block him out sometimes cause he has a ego problem since hes the tire/ wheel person i guess
any info will be greatly appreciated, i have alot of vacation time saved up and plan on using alot of it in the next couple weeks so i can get the jeep whipped into shape before the snow comes, i think ive ordered enough to keep myself busy for awhile hahaha
#2 |
im pretty sure u can run bigger than 32's but its been said before here that we dont really no any answers here we just make stuff up. anybody else no?
2002 WJ I6, IRon Rock Offroad 4", JKs adj. trackbaR, Doetsch Tech 8000 Prerunner Shocks, 275/70/17 BFG AT, Black Moabs, tinted tails, Hellas Alpine IVA-W205 Double din, JL Audio 10w7, Fosgate POWER 600/2, Fosgate POWER 400/4, FOCAL 165V30 |
#3 |
As long as you get the right offset you can run whatever wheels you want, spacers will also help this. Don't listen to the "wheel and tire expert", he doesnt know. If you are going 6.5" and flares you probably want 33's, good gears and proper axle building will let you run them.
Take a look at the Toyo OCMT's, they are a very nice tire with great offroad abilities and good road manners in all conditions. |
#4 |
going bigger then 32 would require having to have it regeared right
#5 |
what exactly is the right offset to go with, for the most part i have a pretty good knowledge of things but when it comes to wheels and tires im lost, never had alot of experience with it
#6 |
I hope you ordered a front driveshaft with that 6.5 lift.
Fill in your information on your rig so we can better help you with your questions.
LET'S GO PSU 04 WJ Laredo I6 5.5" IRO CP 32" BFG M/Ts on JK 17's -Devin |
#7 |
i have a 2000 4.7, i ordered the LA front kit, tom wood driveshaft, added adjustable trac bar, front and rear addco sway bars, bar pin eliminators, jks quick dis, added bilstein shocks, dual steering stabilizer.
in the next few days im gonna order the iceland steel winch bumper and fender flares, smittybuilt winch, kolak exhaust and k&n intake, might possibly add the throttle body as well, still undecided still trying to make a decision on tires and wheels, i know ill prob get some wheel spacers but unsure if i should go with 1.25 or 1.50, from everything ive read anything over 32 in tires is going to be pushing it using the quadra trac system, still not sure if this is true or not, and also running over 32s is going to require regearing from what ive heard/read i think thats about it as of now, am i missing anything that anyone can think of |
#8 |
While you're at it get yourself an NP231 transfer case, slip yoke eliminator, and a double cardan rear drive shaft.
1997 ZJ 5.2, IRO 4.5 - Clayton LA's, 33x12.50 KM2's, 15x10 Soft 8's, NP231 w/ SYE, Rubicon D44's F/R - Air Locker - BTF Diff Cover, CAI, IRO 3" Cat Back |
#9 |
You can run 33s on 6.5" of lift. 35s can be done as well with that much lift. You can get away with 33s and no regearing with the V8 but 35s will probably need a regear.
#10 |
My buddy ran 33's on the old quadradrive and was fine. Guy in our club has a WJ on 34's no issue
#11 |
so what offset do i need to have
#12 |
4". You can get cragar soft 8s for very cheap.
10 char |
#13 |
i looked at some soft 8s and it says for 15x10 -38 offset and 4 rear spacing??? i dont understand any of this stuff when it comes to wheels
#14 |
or should i go with 15x8
#15 |
Stick to 15x8. 15x10 is to wide. Get a 15x8 with 5x5 bolt pattern with 4" of backspacing.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
