Wheels - JeepForum.com
post #1 of 8 Old 01-09-2003, 09:49 AM Thread Starter
rJEEP
Wheels
Hey, I got stock 5spoke wheels on my 98 that have salt corosion. If I break the clearcoat and scratch it, it'll come off.......I was thinking of getting a wirebrush and attaching it to a drill and wirebrushing all 4 wheels then spray clearcoat on them. Anyone have any ideas?
98 ZJ 4.0 HO
rJEEP is offline
post #2 of 8 Old 01-10-2003, 11:05 PM
Need4Boost
Depending on what you use it for...I'd say spray them black!! That'd look cool if you have a lift OR if you are more of a street jeep, then do black, but leave a little gray lip and make the black look good.
just my .02--I would do the same, but I have 5.9 wheels and don't want to spray paint them...They were $$$
1994 ZJ
Built for the STREET--Get over it.
Green Jeep Club Member #13
Need4Boost is offline
post #3 of 8 Old 01-11-2003, 09:18 AM Thread Starter
rJEEP
hmmm....that sounds cool. What kind of paint would be best to use though?
98 ZJ 4.0 HO
rJEEP is offline
post #4 of 8 Old 01-13-2003, 10:26 PM
Need4Boost
Well, just some spray paint would work, but any local auto store should have something that would work for you. If nothing else then spray paint them and make it look as best as possible, also you could get some clear coat and go over the paint to give it a little shine or something...just a thought.
1994 ZJ
post #5 of 8 Old 01-13-2003, 10:33 PM Thread Starter
rJEEP
yea, I think I am going to strip the clearcoat and wirebrush them until all the corrosion comes off. Then I'll spraypaint them with clearcoat and hope that it lasts and looks nice.
98 ZJ 4.0 HO
rJEEP is offline
post #6 of 8 Old 01-14-2003, 12:40 PM
Beachead19
Beachead19's Avatar
If your wirebrush is too abraisive you will have nasty swirls in the metal...even if you spray clearcoat.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #7 of 8 Old 01-14-2003, 12:45 PM Thread Starter
rJEEP
thanks for the warning...What should I use, sandpaper?
98 ZJ 4.0 HO
rJEEP is offline
post #8 of 8 Old 01-14-2003, 12:50 PM
Beachead19
Beachead19's Avatar
If I were doing this project I would visit a local body shop or drop by autozone and ask if there is a liquid you can rub onto the wheels to remove the corrosion and factory clearcoat. Most body shops may have suggestions of their own, you can post them here and see whst others think.
If you haven't already, post this question in "Lifts/Shocks/Tires" forum to see what those gurus say.
And always remember, planning is key before attempting any project.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
New wheels! Robinton ZJ Grand Cherokee Forum 6 01-17-2009 10:59 PM
Kleen Wheels on stock WK wheels (to eliminate brake dust problems) bobholthaus WK Grand Cherokee & XK Commander Forum 6 07-22-2007 09:52 PM
WJ with WK wheels? perrypel ZJ Grand Cherokee Forum 7 09-13-2006 09:43 PM
Wheels nodkaGSR ZJ Grand Cherokee Forum 1 02-10-2005 03:06 PM
Wheels???? Luck881 ZJ Grand Cherokee Forum 2 02-05-2005 10:48 AM
