wheel swap - JeepForum.com
post #1 of 13 Old 07-08-2011, 07:21 AM Thread Starter
white_lexie
wheel swap
I have a 93 zj with a 3.5" lift and have found a really good deal on some 285/70/17 tires. My buddy has some wheels that he took off his charger and I know the bolt pattern is the same but I do not know about the offset and the backspacing. I dont mind if the wheels stick out further I just dont want them sitting in anymore than a stock 15'' zj wheel. Can someone help me out on this?
white_lexie is offline
post #2 of 13 Old 07-08-2011, 07:35 AM
AppSt59Dave
2012 WK
the bolt pattern is not exactly the same.....5x114.3 vs 5x115. it will work but might cause vibration. the offset of the charger is usually a mid offset (+15 to +25 range) and the zj is pretty similar. the rims might be a tad wider from stock depending on which wheel you currently have versus what the charger has. wouldnt see much of a difference honestly.
AppSt59Dave is offline
post #3 of 13 Old 07-08-2011, 08:34 AM Thread Starter
white_lexie
I can get the charger wheels for $60 bucks and the 285/70/17 for $100 bucks so its a sweet deal. Everywhere that I look it says that they have the same 5x114.3 bolt pattern. Is there different bolt patterns of some zj's and chargers?
post #4 of 13 Old 07-08-2011, 09:22 AM
AppSt59Dave
2012 WK
you talking about new body charger? the bolt pattern is 5x115. it will work on a 5x114.3 on the jeep but it can cause problems with the studs sometimes (stretching)
post #5 of 13 Old 07-08-2011, 02:25 PM Thread Starter
white_lexie
Not the newest body like a 2011 maybe like an 2008 or 2009. I dunno if there is a difference in the two as far as the bolt pattern.
post #6 of 13 Old 07-08-2011, 03:03 PM
yzjwk
2005 WK
Can you fit 33x 12 tires on with only a 3.5" lift ? thought you would need 4.5 + to do that .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #7 of 13 Old 07-08-2011, 03:11 PM
AppSt59Dave
2012 WK
either way, the offset is going to be a pain in the *** because its like running a stock wheel.....you will rub the control arm.
'78 CJ-5 Loden Green, in the barn
'12 WK2 Black Forest Green Hemi
post #8 of 13 Old 07-08-2011, 03:13 PM
AppSt59Dave
2012 WK
hit the button too quick.....dont run the charger wheels. a. offset to high for a 285 tire b. going to possible stretch the wheel studs.
skip the sweet deal and get something made for the jeep...unless you are going to run spacers then everything ive said is pointless.
post #9 of 13 Old 07-08-2011, 03:46 PM
Buzz98zj
With trimming you could run 33" tires stock.
98 5.9
Buzz98zj is offline
post #10 of 13 Old 07-09-2011, 06:15 PM
yzjwk
2005 WK
WOW , not my 94 ltd .I could do maybe 33x10.5 with 1" spacers and some trimming, not 33x 12 . i can't even run 31X 10.5 stock without rubbing (smashing into) the control arms . But Then ,that might be different if you had the up country to begin with .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #11 of 13 Old 07-11-2011, 02:05 PM
Buzz98zj
What's up with all the deleted messages? You guys were that crude that it was deleted.
98 5.9
Buzz98zj is offline
post #12 of 13 Old 07-11-2011, 02:07 PM
Buzz98zj
Ya maybe not 33x12 but a skinnier 33". I have seen people on here talk about them or their friends doing it. I personally couldnt trim that much metal off right now.
98 5.9
Buzz98zj is offline
post #13 of 13 Old 07-11-2011, 02:21 PM
1stblack97ZJ
haha it doesn't matter.
I sure like ratmonkey's "reason for deletion" though
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
wheel swap RH31379 ZJ Grand Cherokee Forum 1 06-23-2010 06:51 AM
steering wheel swap mayor_bloom WK Grand Cherokee & XK Commander Forum 6 01-14-2010 12:54 PM
ZJ Steering Wheel Swap with WJ ddeadserious ZJ Grand Cherokee Forum 1 03-09-2009 10:59 PM
Wheel Swap Recommendations wilbur707 ZJ Grand Cherokee Forum 3 03-15-2007 03:54 PM
Wheel swap DonMcL WK Grand Cherokee & XK Commander Forum 2 12-12-2006 08:34 PM
