wheel spacers or not - JeepForum.com
post #1 of 16 Old 02-24-2010, 05:20 PM Thread Starter
cklanish88mj
I am putting 33/12.50.15 pro comp x terrains on my zj i'm using stock jeep grizzly wheels the 5 spoke with polished lip. There 15x7 im thinking 5in backspace or 5.25 do i need to run spacers so it doesn't rub arms and what not? If i do what size spacers should i run?
cklanish88mj is offline
post #2 of 16 Old 02-24-2010, 05:22 PM
wonderbrd937
spacers always make it more of an aggressive look i think, i have 1.25 on my wj with 33x11.5x17 on the rubicon wheels which is 5.25 back spacing i think
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
wonderbrd937 is offline
post #3 of 16 Old 02-24-2010, 05:56 PM
lateralus3
1994 ZJ
how do you plan to put 33s on a stock suspension?
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #4 of 16 Old 02-24-2010, 06:18 PM
Max78
1992 XJ Cherokee
Sorry for the hijack, Care to post a pic? I was looking to get spacers for mine.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #5 of 16 Old 02-24-2010, 06:36 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you'll be rubbing all over the place with only 5" of backspacing.
ratmonkey is offline
post #6 of 16 Old 02-24-2010, 06:45 PM
Technohead
33x12.5x15's on 7" wheels is pushing it; especially if you air down for wheeling. Even 1.25" spacers (a common size) might not be enough. And without 4 1/2" lift and some trimming you will not fit 33's on there anyways.
-Eric
Technohead is offline
post #7 of 16 Old 02-24-2010, 06:46 PM
lateralus3
1994 ZJ
i wish i had a facepalm picture for this thread
Jacob
post #8 of 16 Old 02-24-2010, 06:48 PM
wonderbrd937
this is the best view of the tires i have...sorry
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
post #9 of 16 Old 02-24-2010, 06:54 PM
lateralus3
1994 ZJ
is that your wj? if it is the black and red theme you got going is friggin badass. i would be doing black and red on my jeep if it wasnt blue lol
Jacob
post #10 of 16 Old 02-24-2010, 06:57 PM
wonderbrd937
yes sir =]
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
post #11 of 16 Old 02-24-2010, 06:58 PM
lateralus3
1994 ZJ
wish my jeep was black and red
Jacob
post #12 of 16 Old 02-24-2010, 07:02 PM
wonderbrd937
just made rocksliders and now working on a rear bumper with tire carrier...its in a thread on here, but you should at least get a 3-4 inch lift with spacers and you should be fine.
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
post #13 of 16 Old 02-25-2010, 09:16 AM Thread Starter
cklanish88mj
I am lifting it i just want to use the jeep grizzly wheel i like the look.Reason i ask for what size spacers to run is for turning lock to lock and or flexing it a bit.The spacers will move my back spacing to -what ever thickness spacer from the stock backspacing. What is recommended backspacing for the jeep grand cherokee zj with a 12.50 wide tire
post #14 of 16 Old 02-25-2010, 11:42 AM
dudeinajp
dudeinajp's Avatar
1.25" Spacers will work just fine. I would recommend a good quality set from Spidertrax or Ballistic Fab.
If you decide on Spidertrax, I would call to order to make sure they are in stock. I've seen more than one site saying they are back-ordered until May.
I like the Ballistic Fab spacers because they are the same quality and are $20/pr. cheaper.
Wheel Spacers 5 x 4.5" (pair) with hardware
dudeinajp is offline
post #15 of 16 Old 02-25-2010, 09:22 PM
Ender42
Those tires arent gonna fit unless youve got a good sized lift tho
99 WJ 4.0l Selec-trac. 6.5" Hybrid lift, 33/12.50/15 Maxxis Bighorns, JKS Adj. trackbar. Rancho Stabalizer.. JKS Disco's, Tom Woods Double Carden Driveshafts
76 CJ7, 4.2l I-6, 2 inch body lift
Greater love has no man than this, than he who lay down his life for his friends.
Ender42 is offline
wheel spacers dude979 ZJ Grand Cherokee Forum 4 04-12-2009 12:45 AM
Wheel Spacers jeremy18 ZJ Grand Cherokee Forum 2 12-19-2008 10:07 PM
Wheel Spacers brsox88 ZJ Grand Cherokee Forum 11 11-11-2007 11:22 PM
Wheel spacers are ON! BlaineWasHere ZJ Grand Cherokee Forum 28 02-26-2006 02:17 PM
Wheel Spacers? ERAUTreeTopFlye ZJ Grand Cherokee Forum 5 02-23-2005 04:34 PM
