wheel spacers - JeepForum.com
post #1 of 6 Old 04-30-2013, 07:18 PM Thread Starter
Moparich
wheel spacers
newb question
why wheel spacers and not backspacing? is the selection far less with offset backspacing?
Moparich is offline
post #2 of 6 Old 04-30-2013, 07:25 PM
dnuccio
wheel spacers help if you want to keep your stock wheels.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 6 Old 04-30-2013, 08:01 PM
lawsonej
My spacers
I just put on these wheel spacers on my ZJ. They are 2" wheel spacers on TJ not ZJ cznyon rims, for a total 3.5 Back spacing. It has a two inch lift with isolator left in as instructed. As well, I did some minor trimming on front bumper. Rubbing is rare, but would be more apparent offroad. The trimming done was enough to take away most of rubbing. I am running 31 x 10.50 nokian vativa m/ts all around. Works for me!
lawsonej is offline
post #4 of 6 Old 05-06-2013, 08:27 PM Thread Starter
Moparich
no negative stories or warnings about wheel spacers. when i was working at super shops they were pretty taboo. although these spider trak spacer look completely different compared to the old shim style spacers. ill be putting some 1.25" spacers on my zj to fit the 33's
Moparich is offline
post #5 of 6 Old 05-07-2013, 08:47 AM
Jeeples
Jeeples's Avatar
Correct. There is a big difference between the cheapy shim style spacers (although, several companies make quality versions of this style, but they are typically hub centric and include the installation of longer wheel studs) and the bolt on style that has become popular during the past 10 years or so.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #6 of 6 Old 05-07-2013, 12:35 PM
tucsonzj
I got RC wheel spacers so I could run 31's without rubbing. Now i'll be at 3" of lift so my concern of rub wasn't for fender, but on the CA's and other steering components. So spacers will push the wheel out more and allow the wheel to turn (hopefully to full lock) without rubbing.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
