Wheel shake and ABS light - JeepForum.com
post #1 of 10 Old 02-10-2007, 02:44 PM Thread Starter
travis19
I have a stock 2000 WJ Limited 4x4. My problem is that one day i started to smell the brake pads burning really bad and then my wheel would shake left to right at about 45 MPH and then i tap the brake and it would go away until i stopped and reached that speed agian...I checked it out and the smell was really coming from the passenger side... Next day it went away... a week later after a hard stop i could smell it agian but this time from the driver side and after hitting a few bumps and such my ABS light came on and slowly the smell went away. But now the wheel shakes left to right hard above 45 all the time and it doesn't brake as well as it did before... and there is no pulseation when stopping.
Could it be the calipers and sticking? I know the front brakes were recalled and i am unaware if they were replaced yet or not. Any help would be great
travis19 is offline
post #2 of 10 Old 02-10-2007, 02:51 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
The pads are probably worn out and the rotors need turning. Or, the rotors are warped. Or, the calipers are binding. Or, the steering stabilizer is worn out
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 10 Old 02-10-2007, 02:56 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I would pull the wheel off and inspect the rotor. Is it multicolored or huge ridges cut into it?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 10 Old 02-10-2007, 03:06 PM Thread Starter
travis19
No ridges but they are slightly multicolored ... a little bit of brown in the center... but will that cause the ABS light to turn on as well
travis19 is offline
post #5 of 10 Old 02-10-2007, 03:17 PM Thread Starter
travis19
I just pulled the wheel off the rotor looked a little multicolored and the pads look good without taking off the caliper but when i spin the rotor the pads are really close to it and the rub a tiny bit... i will take some pics of the assembly and repost in about an hour...
travis19 is offline
post #6 of 10 Old 02-10-2007, 04:48 PM Thread Starter
travis19
Alrighty, the brake calipers are the old open style teves caliper... which is the one that causes rotor warpage... but i don't have any warranty on the vehicle so the dealer not going to fix it for free...
travis19 is offline
post #7 of 10 Old 02-12-2007, 01:55 PM Thread Starter
travis19
New pads and rotors and the problem is fixed but the ABS light won't go away.
travis19 is offline
post #8 of 10 Old 02-12-2007, 01:58 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Head to an brake place and have them pull the ABS codes - it should be free.
However you can just start by checking the encoder gear on the axle and the sensor associated with it. Just follow the wire that heads towards the axle (coming down the knuckle) and look for any obvious damage or misalignment.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #9 of 10 Old 02-12-2007, 05:24 PM
K-Pax
K-Pax's Avatar
not sure if this will help you or not, but my brakes would pulsate badly when braking, thought it was just the ABS system....no warning lights came on though. then erratic shaking developed, so i put on new calipers.....shaking went away but not much. this last weekend........2 days ago.....i replaced the rotors and pads as well. rotors were $20 each and pads were $20 for the set. had to bleed the brake lines (all 4) myself....which was fairly easy with the help of a piece of wood between the seat and brake pedal. but now i have no noise, no shimmying, no shaking, no pulsating.......just smoooth braking. feels a little smushy on the pedal still though....i think it's air somewhere in the lines that haven't worked itself out yet.
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
K-Pax is offline
post #10 of 10 Old 02-12-2007, 06:04 PM Thread Starter
travis19
I looked at the cable and no damage... but tonight the driver side brakes started smoking and the smell came back... so looks like i will have to replace to calipers...
travis19 is offline
05 GC 5.7 Highway steering wheel shake xcert WK Grand Cherokee & XK Commander Forum 3 05-18-2009 05:07 AM
ZJ with !bad! shake! Rednecksusa ZJ Grand Cherokee Forum 7 05-05-2009 07:28 PM
Wipers and Light controls on wheel quit working randomly mtb416 ZJ Grand Cherokee Forum 1 03-11-2009 10:22 PM
1 wheel locking up under light braking, jeepunlimited ZJ Grand Cherokee Forum 4 08-26-2007 08:31 PM
