wheel lugs came loose - JeepForum.com
post #1 of 24 Old 05-02-2013, 05:54 PM Thread Starter
dnuccio
was on the highway today and i noticed my ZJ felt kind of like it was drifting a little bit. got to my buddies house (who was following me on the highway) and i told him it felt kind of weird. he told me the left rear was shaking. so i walked over to it, grabbed the tire, and i was able to shake it back and forth. not good lol. im glad i caught it before it sheered the studs off. im just wondering what couldve caused this? the last time i had the wheel off, i did put some antiseize on the studs, but that shouldnt cause them to loosen. i always tighten them in a cross pattern, so i know the wheel was evenly tightened as well. any ideas?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #2 of 24 Old 05-02-2013, 06:07 PM
jeepkid945
Dont put the full weight of the vehicle down when tightening lugs, as it can bind the wheel. Proper torque according to the chart at work is about 115 pounds.
jeepkid945 is offline
post #3 of 24 Old 05-02-2013, 06:31 PM
1skrewsloose
Don't know how far you drove or how severe the shaking, but the studs may have already been stressed. Who knows, a few more miles and the studs may have snapped. Might be worth replacing the studs. my .02.
1skrewsloose is offline
post #4 of 24 Old 05-02-2013, 09:38 PM
WhiteOut
WhiteOut's Avatar
If you put anti-seize on and then torqued to spec, you over-tensioned a lot. The torque specs in the manual are dry torque.
Doing final torque with the vehicle on the ground is fine.
WhiteOut is offline
post #5 of 24 Old 05-02-2013, 10:39 PM Thread Starter
dnuccio
i didnt torque them to spec, just tightened with an x bar tire iron. always done it that way and NEVER had a problem before.
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 24 Old 05-02-2013, 10:41 PM Thread Starter
dnuccio
im not sure how long they were loose for, and i couldnt feel it shaking, just felt like it was drifting a little. that mightve even been because there was a heavy cross wind on the freeway.
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 24 Old 05-02-2013, 10:55 PM
Candymancan
How do you tighten the lugs with the wheel in the air and keep it from spinning if you dont have an impact gun??
Candymancan is offline
post #8 of 24 Old 05-02-2013, 11:09 PM Thread Starter
dnuccio
if its a rear then you can put the parking brake on. otherwise your SOL
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 24 Old 05-02-2013, 11:47 PM
jnicewan
I know what you are saying but the point is valid, and definitely possible. At least get all lug nuts tight as possible.
Also if it was in a 4x4 mode (part time) the rear parking brake will lock the front too
jnicewan is offline
post #10 of 24 Old 05-03-2013, 08:36 AM
KJK
Just snug up the lug nuts and then let down the jack a little until the tire is lightly resting on the ground then tighten them up.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #11 of 24 Old 05-03-2013, 04:01 PM
Candymancan
Yea dughh but Jeepkid said to tighten them in the air.. you cant do that..
post #12 of 24 Old 05-03-2013, 04:08 PM
Maine1994ZJ
Jam a brick or rock or something under the tire to make it not spin.... Also make sure the wheel is flush on the axle before you tighten them. If the wheel's not sitting properly when tightened it will come loose.
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #13 of 24 Old 05-03-2013, 05:13 PM
Candymancan
eh lol i think ill just tighten it on the ground like i always have lol
post #14 of 24 Old 05-03-2013, 05:15 PM
tucsonzj
that's part of the reason for doing the star pattern
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #15 of 24 Old 05-03-2013, 05:57 PM
Slappyman
Wheel studs are one of those little routine inspections you should do fairly frequently....Like checking the oil.
__________________________________________________ __________________________________
1998 Grand Cherokee 5.9 Limited. ** IRO 7" Premium Long Arm Kit. ** IRO OTK Steering System. ** DT-8000 Shocks. ** JKS Quicker Discos. ** AE Wheels Series 185 Rims. ** Mickey Thompson 305/70/R16 Tires.
Slappyman is offline
