wheel bearing vs axle bearing. - JeepForum.com
post #1 of 6 Old 06-21-2007, 12:15 AM Thread Starter
cifer6425
first off i have not searched. i was just going to be lazy and post up.
i purchased my 99 GC back in 04. when i purchased it it had a little noise coming from the back axle. the previous owner said it was a wheel bearing. finally i am getting ready to move and need to sell the jeep, so i am going to fix it. (we don't drive it much.) my local Firestone automotive store said that it could be 1) wheel bearing, 2) axle bearing or 3) center diff.
i really don't think its the center diff. i was going to ask the experts here what they thought. the jeep has right at 125xxx miles.
thanks for the help.
cifer6425 is offline
post #2 of 6 Old 06-21-2007, 01:30 AM
Chrisca
Chrisca's Avatar
If he told you this, do not ever go back there for anything since there is no rear wheel bearing.
Is it coming from the center (diff) or the side (wheel)?
2004 Grand Cherokee Laredo
Chrisca is offline
post #3 of 6 Old 06-21-2007, 02:21 AM Thread Starter
cifer6425
it sounds like the outer side of jeep, not the center. both my father in law and myself agree.
post #4 of 6 Old 06-21-2007, 02:21 AM Thread Starter
cifer6425
double post... my bad.
post #5 of 6 Old 06-21-2007, 07:12 AM
ajmorell
ajmorell's Avatar
It's really difficult to tell. You have to remove the axle shafts either way, so you should just buy both and fix the bad one when you see which one it is. I would say to do all of them (axle, carrier, & pinion), but you're not keeping it so there is no point.
ajmorell is offline
post #6 of 6 Old 06-21-2007, 02:04 PM Thread Starter
cifer6425
thanks for the advice. our jeep is just used as a people hauler when family/friends come into town.
i did not want to do too much work before i sold it. i was going to replace the brakes and have the rotors turned/replaced.
How to replace an axle shaft and/or a wheel hub bearing assembly w/PICS! ArloGuthroJeep WJ Grand Cherokee Forum 340 06-08-2017 10:18 PM
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 09:14 AM
Help! Bent axle, busted wheel bearing? mangle ZJ Grand Cherokee Forum 10 12-04-2007 09:23 AM
Wheel Bearing??? 01grandjeep ZJ Grand Cherokee Forum 9 11-22-2007 05:55 PM
rear wheel/axle bearing Ironworker28 ZJ Grand Cherokee Forum 4 04-30-2006 10:08 PM
