Wheel bearing or differential - JeepForum.com
post #1 of 5 Old 08-13-2017, 12:04 AM Thread Starter
Mopar4U
96 zj limited 133,000 miles
Noticed on decel around 50mph +/- 10 mph a howl. I assumed differential was causing the noise. Recently I noticed on sharp right hand turns at a substantial speed I get a metal on metal rubbing noise from front left.
Could wheel bearing be causing both noises?
Mopar4U is offline
post #2 of 5 Old 08-16-2017, 12:13 AM
GregV98
I think so. I have the same howl at that speed, and from right front. Checked it tonight and it has a little wobble that the left doesn't have. Sounds like it to me.
GregV98 is offline
post #3 of 5 Old 08-16-2017, 08:12 PM Thread Starter
Mopar4U
i took the front wheels off to look for signs of rubbing on the dust shield and saw nothing. i bent them further away for good measure but didnt fix the metal on metal noise. the grinding metal noise only happens on almost 90 degree turns doing 35mph+ for about 1 second.
Mopar4U is offline
post #4 of 5 Old 08-17-2017, 06:46 PM Thread Starter
Mopar4U
i checked the rear dust shields for rubbing and nothing. i tried swaying the jeep left and right while doing 50mph and getting the howl, the howl didnt change. at a loss. seems i have 2 different issues.
Mopar4U is offline
post #5 of 5 Old 08-19-2017, 07:26 PM Thread Starter
Mopar4U
i dont see any marks on the drive shafts that would indicate rubbing. could there be something in the parking brakes doing this? maybe just need brakes and rotors??? pads have plenty of meat, rotors were turned down by po. the sound isnt a sqeueel or high pitched, its very brief and requires the jeep to enter the corner hard to make the sound.
Mopar4U is offline
