wheel bearing - JeepForum.com
post #1 of 10 Old 01-21-2008, 01:48 PM Thread Starter
lothar863
wheel bearing
i think my right rear wheel bearing is bad. i get a nice grinding and poping sound while driving. i dot have a press or access to one. is there anyway i can replace this myself?
lothar863 is offline
post #2 of 10 Old 01-21-2008, 03:23 PM
manofmany
Im not sure if your app requires a new hub or just new bearings. In any case a machine shop probably wouldnt charge but $5
1998 Cherokee 4.0L
1999 Grand Cherokee Limited 4.7L
manofmany is offline
post #3 of 10 Old 01-21-2008, 04:54 PM
_Kyle_
_Kyle_'s Avatar
The hub is pretty easy to change out. Take off the wheel, remove the axle nut, remove the caliper (2 bolts), remove the rotor, remove the hub bolts (3), then pull it off with a cheaper puller from someplace like Harbor Freight for $15. Then do the reverse to install it.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #4 of 10 Old 01-21-2008, 04:56 PM
driabyor
driabyor's Avatar
1994 ZJ
he's talking about the REAR . It involves removing the axles.. Check faq there maybe a write-up in it..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #5 of 10 Old 01-21-2008, 04:59 PM
driabyor
driabyor's Avatar
1994 ZJ
It's an medium on the diy fix scale.... Nice warm garage is a plus... Any special tools can be rented at a part store for a returnable deposit.
5.2 liter 242 :)
driabyor is offline
post #6 of 10 Old 01-22-2008, 07:38 AM Thread Starter
lothar863
thx for the replies. yeah it is the rear. and it doesn't look tough....wish that grage was heated...but other than that the only thing that is making me pause is that the bearing needs to be pressed on. i was looking at this yearterday http://www.stu-offroad.com/axle/usad44/usa-1.htm i also found some forum posts(not on this site) about people freezing the axle and warming the bearing and then taking a pipe and hammer to it and driving the bearing on.......that just doesn't sit with me well. i just don't think it is a good idea to pound on the bearing. but if i am told it will work i can give it a try. i am also going to check to see how much a dealer would charge todo either the whole thing or see if they will just press the bearing on for me. what do you guys think?
post #7 of 10 Old 01-22-2008, 07:43 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
There is no reason a dealer needs to do it, ask around and find a reputable local shop to do it for you.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #8 of 10 Old 01-22-2008, 07:50 AM Thread Starter
lothar863
also do you guys have any brand of bearing to look for? mostly on road with lite off road
post #9 of 10 Old 01-24-2008, 03:29 AM
zupp242
You will need a bearing puller to get the race out. I used a 5/16 thick washer, ground 2 sides flat so it would fit in past the bearing race. With a nut welded to the centre of the washer, thread a slide hammer into it then it will come right out.
zupp242 is offline
post #10 of 10 Old 01-25-2008, 10:37 AM Thread Starter
lothar863
that sucks.... i found a machine shop in the area that will see if they can do it. if i can't get it off will see if they can.
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
Wheel bearing help rmtomasin ZJ Grand Cherokee Forum 14 05-20-2009 06:36 PM
Is this a bad wheel bearing????? FlipFlop425 ZJ Grand Cherokee Forum 4 03-18-2009 06:13 AM
Wheel Bearing??? 01grandjeep ZJ Grand Cherokee Forum 9 11-22-2007 04:55 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
