Whats the difference in these VIC's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Whats the difference in these VIC's?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 07-14-2011, 07:05 PM   #1
airwolf9090
The one in the Heep burned up so i went to the junk yard and the one i got from there has two connectors while the one in my Heep has one connector.... I also got the two connectors out the junkyard Heep is there a way i can splice the two connectors into my Heep so i can use the two connector VIC?
1996 Jeep ZJ Orvis
airwolf9090 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 08:48 PM   #2
JS97ZJ
It looks like you have a 93-95 VIC. Get one from a 96-98.
JS97ZJ is offline   Reply With Quote Quick reply to this message
Unread 07-15-2011, 01:50 PM   #3
muddyjgc
2005 WK
You can't really wire one to work in another because the 96-98 VIC's get alot of its info through the CAN-BUS wires from the BCM, the 93-95's don't have CAN-BUS
muddyjgc is offline   Reply With Quote Quick reply to this message
Unread 07-15-2011, 02:02 PM   #4
MeanGreenZJ
CAN-BUS on a 96-98?
MeanGreenZJ is offline   Reply With Quote Quick reply to this message
Unread 07-15-2011, 03:47 PM   #5
muddyjgc
2005 WK
Sorry I was off a little, Its the CCD data bus network.
Unread 07-15-2011, 06:17 PM   #6
gothchick
We knew what'cha meant! Lol.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline   Reply With Quote Quick reply to this message
