whats better 42re or aw4 - JeepForum.com
post #1 of 10 Old 10-18-2012, 06:20 PM Thread Starter
xcaliber81
i have access to an aw 4 and my 42 re is getting old and will adventually need replacing would it be a good buy, as far as i know its just the tranny no wiring. Is the aw4 a yota tranny?
xcaliber81 is offline
post #2 of 10 Old 10-18-2012, 06:56 PM Thread Starter
xcaliber81
he said to give him a reasonable offer what would be reasonable?
post #3 of 10 Old 10-18-2012, 07:20 PM
jtackerman28
Aw4 is better but I'm not sure the lenght is the same and if not a new crossmember and drive shafts will be required.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #4 of 10 Old 10-18-2012, 07:24 PM
Mickey_D
The Aisin Warner AW4 is an almost bulletproof transmission. The 42RE is almost fragile in comparison. The first year of the ZJ actually came with the AW4 from the factory behind the 4.0.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 10 Old 10-18-2012, 07:25 PM Thread Starter
xcaliber81
sweet how much should i offer
post #6 of 10 Old 10-18-2012, 07:27 PM
LouC
2007 WK
The AW4 has a great rep but swapping to it is not that easy, esp on the 96-98s with OBDII, your older OBDI ZJ it might be easier, but you would most likely have to get the wiring and etc from an XJ of the same year as your ZJ to work. The other option is to rebuild the 42RE with better aftermarket parts, which would be just fine. They can be built very strong with some widely available aftermarket parts.
LouC is offline
post #7 of 10 Old 10-18-2012, 07:30 PM Thread Starter
xcaliber81
i dont think i would attempt to rebuild a tranny, i would pay someone to do it
post #8 of 10 Old 10-18-2012, 07:45 PM
LouC
2007 WK
I'd get the 42RE rebuilt at a shop that builds racing transmissions or heavy duty truck transmissions. The good parts are out there. Keep in mind that the 42RE was based on a 904 style Chrysler Torqueflite which in its day was one of the best transmissions out there the rep suffered because of poor quality of some of the parts and updates (converter clutch and OD) that were not that well done.
LouC is offline
post #9 of 10 Old 10-18-2012, 08:07 PM
jtackerman28
Mine 42 has 204000 miles on it and I beat the snot put of it. Never slips or hesitates to shift. They are reliable as long as you keep a filter and fluid in them, and a reasonable temp.
post #10 of 10 Old 10-18-2012, 08:15 PM Thread Starter
xcaliber81
mine has 475000 kms lol, but anyhow if its better to keep the 42 ill do it since you guys are experienced in jeeps thanks
