What year 231 should I look for? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > What year 231 should I look for?
Price match at JeepHut.com20 Ton Press Brake DIY Builder Kit @ Swag Off RoadFenders for your Jeep at Jeephut.com
Unread 12-22-2014, 06:36 PM   #1
evan1395
Well driving my Aussie in the rear end accompanied by the 249 for 2 weeks was enough reason to pull my front shaft off again and move onto getting my 231. I read and read and read on numerous threads reguardinflg the 249 to 231 swap.
Supposedly some earlier model 231's came with a shorter front output shaft, is this correct? If I dont want to bother (or atleast try my best) with cracking open my donor 231 case and swapping my 249 front output shaft in, what year 231 would be the most ideal to look for? I
Any and ALL input/knowledge on this subject is appreciated.
J.E.E.P (Just Empty Every Pocket)
evan1395 is offline   Reply With Quote Quick reply to this message
Unread 12-22-2014, 07:37 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
Any ZJ 231 should work unless it was behind an AW4 (early 93) as for XJ any 96+ case would work.
Since you have the second gen and therefore NOT the 46rh your options are pretty good. In theory a tj case would also swap.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 12-22-2014, 07:46 PM   #3
evan1395
So no 93' ZJ 231 and any 231 from 96+ on XJ's and TJ's?
As for front Driveshafts, ANY ZJ or XJ U joint double cardan shaft will work along with the front pinion yoke, right? Should I get one that is slightly longer than what I have now? What points do i measure from on the shaft to determine length?My apologies for all the questions, but driving around with 2WD right now is a freaking dream, I really want to get this 231 case all done.
Your replies are always apreciated kg6mov!
Unread 12-22-2014, 08:13 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
Late 93 42re based 4.0's should work, I would tend toward a 96+ to be on the safe side.
Front pinion yokes are all the same, I've got a 99 XJ 231 on my bench right now and it bolts up to my niner front shaft fine.
You will find that the 231 may have an external slip yoke where your 249 should be internal slip yoke. In that case you will need to shorten your driveshaft an inch or so.
Edit: Per the XJ Section FAQ all 96+ 231's are external slip yoke, while I can't find the same stat on the ZJ or TJ I assume that is true of any 96+ 231.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 12-22-2014, 08:59 PM   #5
evan1395
Then down to the junkyard it is in search for a 96+ 231
It would be a wise move to snatch the linkage off the XJ that I pull the 231 from I assume.
Unread 12-22-2014, 09:05 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
You need the selector tab but the rest can be converted, I tend to pull as much ancillary gack when I pull something from the JY, can't hurt.
Oh, and I would highly recommend tossing a rebuild kit at it before you do the install. Don't want any surprises after you get it installed.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 12-22-2014, 09:18 PM   #7
evan1395
What is the selector tab? Have any pictures? With that aside, is there anyother bit of the linkage I need?
What does the rebuild kit consist of for the 231?
Unread 12-22-2014, 09:25 PM   #8
kg6mov
Hears the voices
kg6mov's Avatar
The selector tab is the piece that bolts to the actual case, rectangular bit that drives the shift forks on the inside.
The rebuild kit is new bearings, shift fork pads, and seals. You need new seals and such if you are going to crack the case as some get destroyed in the process. I would highly recommend cracking the case to see if anything is messed up. If the shift fork pads go missing bad things happen. The rest is just good to do while you have it off the jeep.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 12-22-2014, 09:32 PM   #9
evan1395
Ok cool. Can the bearings and seals be installed with a non marring mallet? No press or puller required?
Unread 12-22-2014, 09:42 PM   #10
kg6mov
Hears the voices
kg6mov's Avatar
As far as I can tell from the FSM yes. Most (all?) of them are retained by snap rings so the most important tool for teardown is a good set of snap ring pliers.
I've got a rebuild kit on order for the one on my bench, I'll post a writeup once I get it back under the jeep.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 12-22-2014, 09:46 PM   #11
MurdaJs
Depending on the 231 you might have to cut the caged bearings off the mainshaft. Then hammer on a new one.
Earlier 231s used caged bearings later ones just had a machined surface instead.
Built one piece at a time, and it cost me many dimes
MurdaJs is offline   Reply With Quote Quick reply to this message
Unread 12-22-2014, 09:52 PM   #12
evan1395
Nice. Ill be looking forward to that write up. Which rebuild kit did you go with?
Unread 12-22-2014, 10:00 PM   #13
kg6mov
Hears the voices
kg6mov's Avatar
I went with a ebay one as the part numbers looked good. One of the basic kits that doesn't include the chain is fine. Then do chain if you decide it's bad (or do a wide chain upgrade from JB conversions). The rest of the parts can be found on quadracrap, and if it were my jeep I'd probably just get their rebuild kit.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 12-22-2014, 10:22 PM   #14
evan1395
What should I look for as for the condition of the chain goes?
Unread 12-22-2014, 10:28 PM   #15
kg6mov
Hears the voices
kg6mov's Avatar
While the case is still together (tailcone has to be on for the mainshaft to be supported on both ends) you should be able to reach in through the fill hole and check the tension. A little slack is normal, touching the case is bad, but you kinda have to play it by ear.
"Coulda had a V8!"
96 build thread
Niner build thread
