What would make your heat not get hot? - JeepForum.com
post #1 of 14 Old 12-11-2009, 09:42 AM Thread Starter
WXman
I have a new radiator, new heater core, new evap. core, new coolant. No leaks that I know of. Engine runs great. For some reason, my heat doesn't get hot anymore. This morning I drove it for 30 minutes to work and it was 17 degrees outside and the Jeep got somewhat comfy...but it never would get warm inside. Any ideas??
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #2 of 14 Old 12-11-2009, 10:14 AM
impuresoul2k3
Did you bleed the system? How's the coolant level?
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #3 of 14 Old 12-11-2009, 10:15 AM
StrokedWJ
StrokedWJ's Avatar
Did you replace the thermostat? Does the engine temp ever reach the 195 mark?
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #4 of 14 Old 12-11-2009, 10:22 AM
EisBlade
EisBlade's Avatar
What happened for you to get all those new items in the first place? I don't see a thermostat listed. Go get a new one and compare it to yours. Keep in mind that sometimes even a new thermostats dont' work properly. "Stant" makes good ones.
If you are only getting warm and not hot, it could be that your thermostat is stuck in the OPEN position - not keeping the water in the engine long enough to heat up. Your engine isn't running at optimum operating temperature either.
When cold, a thermostat should be in the CLOSED position. As the engine heats up it begins to open and allow water to pass through to the radiator to get cooled. A good way to test thermostats at home is to put it in a pot of water on the stove and allow the water to reach boiling. Once boiling, pull the thermostat out with a set of metal tongs or large spoon and check to see if it is in the OPEN position.
JT
Facebook: Harley-Davidson Touring Group
EisBlade is offline
post #5 of 14 Old 12-11-2009, 12:30 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
and wash the pot out before your wife decides to use it to cook dinner and you get funny tasting ziti.
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
post #6 of 14 Old 12-11-2009, 12:43 PM
the88thpianoman
2003 WJ
Could be a blend door or AC actuator issue as well, if the engine is reaching proper running temp.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #7 of 14 Old 12-11-2009, 04:56 PM
EisBlade
EisBlade's Avatar
OP, what is the highest temperature your gauge reads once the engine has ran long enough to be at its hottest temperature when idling?
JT
EisBlade is offline
post #8 of 14 Old 12-12-2009, 07:06 AM Thread Starter
WXman
Well my rad had a leak early this year so I got a new one. Then in the Summer my AC wouldn't hold a charge so I traced the leak to the evap core. Changed the heater core while I was in there. The coolant obviously is all new...the level is fine with no leaks now. My engine runs at 220....the very middle of the gauge. I did not replace the water pump or t-stat yet. But if it runs at normal temp then that should be ok right? The blend doors seem to blend the air properly. I guess it has to be the temp control dial..right?
WXman is offline
post #9 of 14 Old 12-12-2009, 07:15 AM
ZJPunk98
Well if your engine is running at the correct temp, then your water pump must be fine and is circulation the coolant.
This could be a blend door problem. Especially since its cold out (or really hot out), you will notice the malfunctioning blend doors the most. They will allow to much cold air to enter the system, thus over cooling your hot air. This could be why you have only warm air.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #10 of 14 Old 12-12-2009, 09:29 AM
steeleman3
I have the same problem, never seems to blow hot only warm air at the most. Only my temp guage is almost always at its lowest point, not in the middle
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #11 of 14 Old 12-12-2009, 09:32 AM
97DCZJ
heater core. to replace it, you need to rip your entire dash apart
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #12 of 14 Old 12-12-2009, 11:56 AM
Tiggerrrrr
Buy a new 195 degree thermostat. It sounds like yours is too low of a temp or it's stuck open.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #13 of 14 Old 12-12-2009, 06:51 PM
EisBlade
EisBlade's Avatar
EDIT: x2, a thermostat is needed. (I type too slow)
The OP's, well, if it's reaching correct operating temp then his thermostat working fine. The dash will have to be pulled (passenger side) and, like 96DCZJ mentioned, the heater core needs checking. If it gets hot when the engine reaches normal temp. then that works. Air blows across, warms, and gets blown inside. After that, focus on the blend doors. They may be stuck open and allowing too much cool air to pass into the cabin area.
JT
EisBlade is offline
post #14 of 14 Old 12-13-2009, 12:07 AM
97DCZJ
Just actually read the original post, and noticed you mentioned you installed a new heater core, so ignore my last post.
if your temperature isn't at 190 at the least, bad thermostat. I was running a 160* thermostat up until last week, and it only blew warm air because the engine wasnt hot enough to blow hot air.
; V8 4.7L, Stock.
97DCZJ is offline
99 WJ with manual ac/heat controls blows heat then turns cold GA350 ZJ Grand Cherokee Forum 10 01-04-2009 09:59 PM
Manual Heat Only (No Auto Heat) FFuries ZJ Grand Cherokee Forum 0 09-27-2008 05:25 PM
no heat in cab. 5.9 ANDY ZJ Grand Cherokee Forum 8 08-09-2008 12:41 PM
No heat/ac davidtwyman ZJ Grand Cherokee Forum 4 10-02-2007 07:47 AM
Blend Door Woes! No Heat! No Heat What so ever 3 ERROR CODES! Polaris Junkie ZJ Grand Cherokee Forum 4 09-20-2006 10:05 AM
