what wires go where? - JeepForum.com
post #1 of 5 Old 02-15-2007, 05:46 AM Thread Starter
joshjeep04
Ok so found the problem to my pcm failure. Seems that the wires going to the rear oxygen sensor were ripped out and all tangle together i guess they got cuaght up in the drive shaft. Then i had found the the front ones wiring had melted to the exhuast but didnt break any wires could this have been the problem that one of them shorted out and cuase the cumputer to fail? Well anyway i need to find out which ones go where. It looks like the previous owner had changed the rear sensor and had the wires spliced together i dont know why but that is where the ripped out from and now i dont know which ones go where there are 2 grays and 2 white wires coming out of the seson and there are it looks like 2 purple and white wires the are twisted together and 1 black and 1 green wires hanging by the t-case thst go to the sensor.
joshjeep04 is offline
post #2 of 5 Old 02-15-2007, 06:25 AM
rm2001wj
rm2001wj's Avatar
The answer to a question like that usually requires knowledge of the model year and engine. Putting that info into a signature means people don't have to ask for it if you don't mention it otherwise.
rm2001wj is offline
post #3 of 5 Old 02-15-2007, 09:09 AM Thread Starter
joshjeep04
it is a 96 laredo 4x4 with the v8
post #4 of 5 Old 02-15-2007, 09:26 AM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
This should be what you're looking for.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #5 of 5 Old 02-15-2007, 10:53 AM
rm2001wj
rm2001wj's Avatar
That schematic is basically what's in the '97 and '98 FSMs also. What it shows is that that wiring harness containing wires coming from the PCM for the downstream sensor should contain: a BK/PK wire for the sensor signal, a BK/LB wire for the sensor ground, a DG/OR wire for the sensor heater positive voltage, and a BK/TN wire for the heater negative (same as ground).
Those colors don't match any that you mentioned and that's a problem. You need to follow the hanging wires that go back to the engine compartment to see if there is another splice which has wires matching the colors above. If you find the correct colored wires, then that will solve most of your problem. The rest will be solved with the instructions that come with the new O2 sensor; they will identify corresponding wires coming from the sensor.
rm2001wj is offline
Where to run AUX wires? J_Minnesota ZJ Grand Cherokee Forum 14 12-01-2009 08:06 AM
VIC wires 98zjteen ZJ Grand Cherokee Forum 1 04-04-2008 04:22 PM
battery wires 97GrandCherokee ZJ Grand Cherokee Forum 4 12-01-2006 04:21 PM
MSD Wires NuTone ZJ Grand Cherokee Forum 1 03-15-2004 06:40 AM
7mm wires rJEEP ZJ Grand Cherokee Forum 1 12-27-2002 04:02 PM
