What is that whistling/whining noise? - Page 2 - JeepForum.com
post #16 of 38 Old 10-21-2010, 08:58 AM Thread Starter
jlconlin
Originally Posted by KennzX View Post
Mine does it when ever irs slightly cold and a little moist. Its my AC clutch. Like if it starts whistling and you jump the gas a little it goes away?
If I push on the gas, the pitch of the noise goes up until it hits a certain point and it goes away. When it shifts to a higher gear, the noise returns.
jlconlin is offline
post #17 of 38 Old 10-21-2010, 09:00 AM Thread Starter
jlconlin
Originally Posted by freakinheep89 View Post
if its an RPM dependent whistle its probably a vacuum leak. check your IAC valve for proper adjustment, check all the vacuum lines to see if one is disconnected or cracked. The only other "whistle" I know of is the transmission at speeds due to restricted flow but thats usually due to a clogged filter and you changed that.
are you sure its a whistle? and not maybe a bearing whine? the idler pulleys make an interesting whine noise almost like a supercharger when they go bad.
It could definitely be a whine instead of a whistle. I'm going to try and see if I can isolate what is making the sound and report back.
jlconlin is offline
post #18 of 38 Old 10-21-2010, 09:01 AM Thread Starter
jlconlin
Originally Posted by phitmein View Post
"are you sure its a whistle? and not maybe a bearing whine? the idler pulleys make an interesting whine noise almost like a supercharger when they go bad."
A Very good point there Freak and the easy test there is to remove the belt/belts and start it,rev it and see if the noise is still present or not ...
Edit: Freak, let's not forget about power steering whines too ...
I'm pretty sure it's not a power steering whine. I've heard that before and it is different than what I'm hearing now.
jlconlin is offline
post #19 of 38 Old 10-21-2010, 10:30 AM
Tweaks
I am having the same problem. It's been around for a long time (months) and I have just been way too busy to spend time going after it. I think mine is making noise from the pulley on my alternator. It used to squeak alot and was worse on rainy, damp days and now it just whines like it's supershraged. Does it in park and it's rpm dependent. Anyone else had this happen and had it be the alternator?
Tweaks is offline
post #20 of 38 Old 10-21-2010, 02:48 PM
freakinheep89
What motor do you have? 4.0 or 5.2?
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #21 of 38 Old 10-21-2010, 04:36 PM
gothchick
The noize you are hearing is the sound of the hidden turbo spooling up on selected models of 95' ZJs.
JK.
gothchick is offline
post #22 of 38 Old 10-21-2010, 04:58 PM Thread Starter
jlconlin
I have a 1997 Grand Cherokee Laredo with 6 cylinders and a 4.0 liter engine. It also has the towing package, but I doubt that has anything to do with the current problem.
jlconlin is offline
post #23 of 38 Old 10-21-2010, 05:08 PM
freakinheep89
Check the idler pulley, its the one that seems like it does nothing but spin. Also disconnect the belt and remove it, then start it and see if the noise is gone. that will let you know if its related to a pulley or a vacuum leak.
TJ-
post #24 of 38 Old 10-21-2010, 05:41 PM
bigbossd1030
If it is a bearing do what Phit said with the stethiscope pipe, unless you have a real one.
That way you are not swapping out pulleys you don't need to.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #25 of 38 Old 10-22-2010, 05:33 PM Thread Starter
jlconlin
So I bought a short PVC pipe to see if I could isolate where the noise is coming from and now I can't reliably reproduce it. I can still hear it, but it is intermittent. I have to keep playing with it to see if I can figure out what is wrong.
jlconlin is offline
post #26 of 38 Old 10-23-2010, 02:32 AM
phitmein
phitmein's Avatar
OK, you are going to be brave and use the PVC pipe instead of a hose ...
Not very smart, but that is how I have rolled many a time ...
Hose works better sometimes when you need to get to a sneaky place underneath and around something that a unflexable pipe won't reach ...
When I use hose, I go to Lowes or the like and buy the thin clear hose like on a fish tank, but I buy the big stuff with like a 1/2 inch ID ... It works like a champ ...
When you use your PVC pipe, be sure not to hold it straight out from your ear, but instead have it parallel to your face and ear ...
Go for it, but be very careful ...
Phit
phitmein is offline
post #27 of 38 Old 10-23-2010, 03:00 AM
Falkon
JK.
vehicle:car: engine: supercharger
Internal turbo
Internal Turbocharger
(+1, -3) [vote for,
against]
Maybe this sounds crazy -- but as any engine runs theres exhaust. And that flow of spent gasses already moves pretty quick. So in elimination of a need of a complex turbo, why cant we run the gas flow from the exhaust valves directly to the intake runners? This would improve efficiency of the engine while only adding minimal cost. Let me know if I am crazy but I think this would work as long as we could somehow add a Mass Air flow sensor so that the ecu knows how much fuel to dump in.
Cardude, Jun 04 2008
Falkon is offline
post #28 of 38 Old 10-23-2010, 03:19 AM
phitmein
phitmein's Avatar
OK, I just re-read the whole thread here once again and I am thinking Freak is right on the pulley/bearing thing ...
Have you pulled off the belts yet, to see if it goes away when running ???
I saw, that you said, it starts making noise after 15 seconds and that maybe how long it takes for bad bearings to heat up and start complaining ... IMHO ...
I did not see you mention that the engine was acting differently/weird ...
A healthy/loud vacume leak would do that I think ...
Pull the belt/belts, spin everything that will spin easily with you hand and check for side play and end play etc. ...
Phit
phitmein is offline
post #29 of 38 Old 10-23-2010, 07:14 AM
78fbta
It could be the front pump in the tranny starvin for fluid,it will make the same noise.
78fbta is offline
post #30 of 38 Old 10-23-2010, 09:38 PM Thread Starter
jlconlin
I wish I could give you all an update, but as I said in an earlier post, I can't get the engine to whistle reliably. Since I can't reproduce the whistle when I want, I can't go searching for what is making the sound.
On the other hand, if it doesn't whistle anymore, that solves the problem right?
jlconlin is offline
whistling noise? Mudzilla6661 ZJ Grand Cherokee Forum 9 02-16-2010 07:06 PM
Another day, another noise - whining noise while accelerating and slowing swataz ZJ Grand Cherokee Forum 8 12-11-2008 10:05 PM
Wierd whining whistling noise WhiteOut ZJ Grand Cherokee Forum 1 11-14-2008 10:12 PM
whistling noise when a/c is on ruff88xj WK Grand Cherokee & XK Commander Forum 3 07-22-2008 03:35 PM
cherping noise/whining noise coming from passanger side LoweBudget ZJ Grand Cherokee Forum 0 12-06-2002 12:10 PM
