What is this Valve? - JeepForum.com
post #1 of 7 Old 05-23-2009, 08:40 AM Thread Starter
Redrum_1
What is this Valve?
Can anyone tell me what this vacuum valve is called and its purpose? Maybe even a link to buy one online. I couldn't find it listed at www.rockauto.com .
Thanks...
http://i280.photobucket.com/albums/k...rottleBody.jpg
2013 Dodge Ram 1500 Express Quad Cab. 5.7L Hemi 6 speed automatic 3:55 gears LSD with 20 inch rubber
2000 Jeep Grand Cherokee Limited 4.0L
2003 Nissan 350Z Enthusiast Model 6 speed manual
2002 Audi A6 Avant Quattro 3.0L Auto
Redrum_1 is offline
post #2 of 7 Old 05-23-2009, 08:42 AM
rugermack
Looks like a simple check valve, allows vacuum to flow only one way. Try checker or auto zone or a place like that.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #3 of 7 Old 05-23-2009, 08:57 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Yes, that looks like a simple vac check valve.
But with the other end of the hose being connected to nothing, it's not doing much work...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 7 Old 05-23-2009, 03:01 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
not sure why it has one there, mine doesn't.
other end of that goes to the evap canister.
ratmonkey is offline
post #5 of 7 Old 05-23-2009, 08:00 PM Thread Starter
Redrum_1
I stopped at the Jeep dealership this morning and found out its hooked to and part of the Duty Cycle Evap Purge Valve PCM Output. How did I find this out you ask? They sure didn't know. They couldn't find the valve in their parts books either. Even better the Chrysler Rep was there and he had no idea what it was or where to find it. I asked to look at their book and I found what I just told you about it. Not much info on it. Reason I asked is thats the only thing missing after I changed Engines and thought maybe it had something to do with my idle surging from 400 to 1400 and back and forth.
Hell, I've tried everything else.
Thanks...
Redrum_1 is offline
post #6 of 7 Old 05-23-2009, 10:06 PM
Tam Vu
Back in the day I had a Honda that did that after I worked on the cooling system. I didn't completely bleed out all the air causing to idle like you mentioned. Don't know if the V8 Jeeps have this trait. I did my 4.0's system in the winter and there was no bleed valve to be found.
Tam Vu is offline
post #7 of 7 Old 05-24-2009, 08:50 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
my 94 and 95 V8s both have it.
HighLonesome is offline
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 05:08 PM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 10:15 PM
Need Help With 95 Gc Egr Valve phjohnso ZJ Grand Cherokee Forum 2 12-16-2003 11:28 AM
Pcv Valve CATMAN2 ZJ Grand Cherokee Forum 4 12-11-2003 11:40 PM
EGR valve and IAC valve dmask0 ZJ Grand Cherokee Forum 1 11-02-2003 01:39 PM
