What is this under the transfer case shifter knob? (PIC) - JeepForum.com
post #1 of 19 Old 11-25-2008, 08:29 PM Thread Starter
GibsJeep
Pulled off my t-case knob and found this little rod coming out of the lever. This rod has up/down and side to side play in it and I dont see it as serving any mechanical purpose. All I know is that it fits right in the center of the underside of the t-case shifter knob.
Pic.......
Does anyone know what its purpose is??
I ask because Im getting a threaded adapter custom made for 8 ball shifter knobs and the like .
GibsJeep is offline
post #2 of 19 Old 11-25-2008, 09:10 PM
The Donger
Pic.......
I couldn't tell ya if it serves any mechanical purpose; since the t-case shifter has no detent system, I would say none?
But... When you buy or make your threaded adapter post it up, that's a pretty sweet idea.
1996 ZJ 4.0 4X4
Bored TB, K&N Filter (OEM Replacement), Edelbrock RPM Series Muffler
1" KOR BB & Up-Country
The Donger is offline
post #3 of 19 Old 11-25-2008, 09:34 PM
JCZJ
that's probably what gets pushed down to go into N or 4LO.
1998 ZJ // 5.2L // Lifted!
1994 ZJ // 4.0L // 271,000 miles // Some cool stuff // RIP 5/25/08
1965 Ford Mustang 2+2 // Boss 302 Swapped // Locked 9" rear
Originally Posted by Shoey40 View Post
She can XJ my WJ whenever and however she wants. Hell, I'd let her CJ it, too.
JCZJ is offline
post #4 of 19 Old 11-25-2008, 09:57 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You are supposed to push down to go from Neutral to 4-low.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 19 Old 11-25-2008, 09:59 PM
nocluejimbo
2012 MK Patriot
Maybe on the 242, but on the 247, the mechanism shifts into N or 4 LO without the need to push down.
nocluejimbo is offline
post #6 of 19 Old 11-25-2008, 10:09 PM
CMARJEEP
CMARJEEP's Avatar
Maybe they use the same lever for all transfer cases but it doesn't serve a mechanical purpose in the 247.
CMARJEEP is offline
post #7 of 19 Old 11-25-2008, 10:25 PM Thread Starter
GibsJeep
Hmm, maybe thats the case , but thats for sure though, the lever does not need to be pushed down at all for the 247.
I'll definitely post it up once I get it all done.......Thanks guys
GibsJeep is offline
post #8 of 19 Old 11-25-2008, 11:09 PM
The Donger
Boy was I wrong!
But I do have a 249 so it wouldn't apply to me anyhow.
1996 ZJ 4.0 4X4
post #9 of 19 Old 11-26-2008, 12:20 AM
sandman
shift it and see what it does.
1993 Jeep ZJ. 4.0
sandman is offline
post #10 of 19 Old 11-26-2008, 05:02 AM
kentman
kentman's Avatar
2006 XK Commander
Ejector seat. Don't ever push the red button.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #11 of 19 Old 11-26-2008, 07:55 AM
JeepOrvis97
JeepOrvis97's Avatar
I actually have a red button wired in that just sits on the end of the wire next to my seat, I always say its the ejector seat button because the reason its there(air horns) doesn't work right now.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #12 of 19 Old 11-26-2008, 03:16 PM Thread Starter
GibsJeep
Did that and it does nothing.
I think what cmar stated is correct, that its for the 242 and it may be that the factory used the same shift lever for all of the transfer cases available on the WJ. So for the 247, it serves no purpose being how the t-case lever does not need to be pushed down when shifting.
GibsJeep is offline
post #13 of 19 Old 11-26-2008, 04:03 PM
WJ04
Mabey it's there for when you do your 247 to 242 swap, then it will need to be pushed down for 4Lo......
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #14 of 19 Old 11-26-2008, 05:30 PM
vwmaniacx
Push down..ha. Who needs to do that, I cut mine out cuz it wuz giving me problems.
you can go a long way with a smile . You can go a lot farther with a smile and a gun . -Al Capone
vwmaniacx is offline
post #15 of 19 Old 11-27-2008, 04:23 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Flux capacitor early modification...
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
How To Get Shifter Knob Off WJ? BlackSS WJ Grand Cherokee Forum 10 07-22-2010 08:25 PM
Custom t-case shifter knob *PICS* GibsJeep ZJ Grand Cherokee Forum 3 01-23-2009 06:53 PM
WJ transfer case knob jeepster2000 ZJ Grand Cherokee Forum 4 04-01-2008 12:47 PM
Transfer Case Shifter Leak Help slik97zj ZJ Grand Cherokee Forum 4 03-07-2007 12:15 PM
Transfer case leak at shifter seal 99flajeep ZJ Grand Cherokee Forum 1 12-01-2003 02:46 AM
