#1 | |
What are they worth?
How much are my D30/44a Vari-lok axles worth? They have slotted/cryod rotors front and rear, JKS HD tierod, diff skids front and rear, 3.73's, and have been well taken care of. I also have spare shafts front and rear.....
MODS: Move/delete if its not "tech enough". Figured WJ guys could give me the best answer ![]()
1998 Dodge 2500 QC LB 4x4 675whp 1450wtq 12v, Suncoast trans, D80, 35" Red Letters 2002 WJ Limited 4.7 HO, 6.5" LA, 37's, JK 44's SOLD
#2 |
I see used differential from $100 ea to $400 ea complete. As for what these particular diffs are worth I'm not sure, but that is what I find complete diffs going for. Also different parts of the Country bring different prices. Might go to carparts.com & see what they are getting or asking I should say.
#3 |
Built and Supercharged 47
you should sell me the diff skids and the tie rod
Built Beater 01 WJ MY BUILD THREAD Swapped, SUPERCHARGED Locked, Lifted and Long Armed. 02 Cummins. It has a smoking problem, And it wont quit. K8 GSXR 1000- Jardine,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, B&N |
#4 |
Infowars.com
I sold an almost stock 8.8 for $450 not to long ago, all it had was an Aussie in it. I would say anywhere from $150 to $450 each depending on how smart the buyer is.
What is it about Ron Paul?
#5 |
Veri-lok? Not worth much at all.
Vari-lok? what they said. ^^^ |
#6 | |
Luck favors the prepared
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap. Check out my build thread here: Life lessons and budget build |
#7 | |
Thanks for all the help guys ![]()
#8 |
Rubber Ducky Jeep
if someone wants vari-lock diffs they are about 700 new. and the only way to get them is to buy new or find a good working unit, cause they aren't serviceable. so if someone really wants them you can price it high.
with that being said, i would gladly buy the D30's vari-lock diff and axle shafts for $10 i don't need the whole axle, mine are fine the way they are. |
#9 |
Mr. Hyde!
D30 about $100-150 tops...
D35 about $50-$75 tops. D44a about $200-$500 (totally depends on the local market). I had a hell of a time selling my D35 - almost had to give it away.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#10 |
give them to meeeeeeeeeeeeeeeeeeeeeeeeee
3.5 BDS, Rancho 9000xl shocks, 31x10.5x15 BFG A/Ts, KOR lower rad support, JKS quicker discos, Hella 500s, 3" magnaflow exhaust, KOR-alike Roof Rack, IRO tie rod...bunch of other stupid crap. Greatest Thing You've Ever Seen |
#11 |
How long have the 35's been on?
How much did the PO wheel with that setup? I would be very cautious about buying those...
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD |99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009 If it aint broke, fix it till it is. |
#12 |
You should take the tie rod and skids and after market stuff on the axles off. You can make more this way unless you find someone who wants all that and is willing to pay a little extra.
#13 | |
![]() 35's have been on for about 20k miles, PO never wheeled the rig, at all. Front axle has even had the ball joints replaced in the past year. Hub/wheel bearings are tight still.
#14 |
how noisy are they ?
i'd say up to a 100 for the 35 and up to 350 for the 44a . thats what i'd give you at least :] |
#15 |
They don't make any noise.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
