what spark plugs on the 4.0? - JeepForum.com
post #1 of 8 Old 11-18-2009, 01:51 AM Thread Starter
madrabbitt
madrabbitt's Avatar
I know the 4.7 has to have specific special copper core plugs, but does the 4.0 care?
I know the 4.0's in my cherokees ran like crap with expensive platinum and multi-point plugs, and prefered the cheap champion 1.99 truck plugs, but what about this newer 4.0?
I've had it for about 60 thousand miles, and the last thing the PO did was change the spark plugs to correct a cyl 5 misfire... dont know what plugs he used.
I've had 3 CEL's in the last few months. Cyl 5 misfire, Cyl 4 misfire, random/multiple cyl misfire.
All were on long trips, and all corrected themselves within a few days.
I figured spark plugs would be a good place to start.
The plugs that one of the fleet mechanics said to use are either champion plat power, PN#3034 , or autolite platinum AP985
both are stocked parts at my autozone, both are 2.99 each.
Anyone have any other suggestions?
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #2 of 8 Old 11-18-2009, 02:05 AM
the88thpianoman
2003 WJ
Typically the cheap champion or autolite copper cores are the way to go, even on the new 4.0. You will not see any difference in performance or mileage with any type of fancy plug. However, a basic platinum plug should last quite a bit longer than the copper on our distributorless ignition system. On my last change I put in autolite platinum plugs because they were on sale for the same price as copper. It's been said on here that the single platinum plugs will last about 70k miles with our ignition.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 8 Old 11-18-2009, 02:17 AM Thread Starter
madrabbitt
madrabbitt's Avatar
so knowing that the current plugs have around 65k miles on them, its probably time to change them then?
post #4 of 8 Old 11-18-2009, 06:50 AM
Boodyrider
The correct autolite plat is the APP985 for the newer 4.0, NOT the AP985. Lare amounts of real world experience say they DO make a difference, as did the Champion truck plugs for the older 4.0.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #5 of 8 Old 11-18-2009, 11:02 AM
96ZjBurner
Well I have akways used bosch iridum fusion in my cars and currently that's what's in my 4.0 zj and I haven't had any problems since but I prolly will go with the coopper ones from champion due to the fact that's what 4.0s want and work best with
Just Empty Every Pocket.
Flowmaster Super 44 Off-Road
96ZjBurner is offline
post #6 of 8 Old 11-18-2009, 12:58 PM Thread Starter
madrabbitt
madrabbitt's Avatar
ok, so not double tip plat, but plat tip and electrode.
i'll see what autozone has
post #7 of 8 Old 11-18-2009, 03:16 PM
the88thpianoman
2003 WJ
Care to elaborate on that? The plugs I have in right now are the single platinum AP985, not the double APP version. What differences have people experienced?
post #8 of 8 Old 11-18-2009, 03:45 PM Thread Starter
madrabbitt
madrabbitt's Avatar
yeah, i'd like to know more please.
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 06:17 PM
spark plugs 99 gc tattoocharger ZJ Grand Cherokee Forum 7 12-15-2008 11:50 AM
WJ Spark Plugs FlipFlop425 ZJ Grand Cherokee Forum 19 10-14-2007 06:11 PM
Spark plugs??? Diehard ZJ Grand Cherokee Forum 16 07-25-2006 09:03 PM
Spark Plugs Othoni ZJ Grand Cherokee Forum 4 04-24-2005 09:12 PM
