What size tires can i fit? - JeepForum.com
post #1 of 5 Old 04-06-2009, 06:36 PM Thread Starter
shdybrady19
Hey guys I am going to upgrade my 31x10.50's to something alittle bit bigger. I cant really give you an accurate size of lift bc its a mut lift. Somewhat pieced together. But it had a 4 inch lift and after my 8.8 i am putting a set of used 6 inch lift springs. But Im not sure how much they sagged. What iw as wondering if I could get measurements maybe from the ground to the top of the fender or something and we can estimate if i can fit 33' inch km2's
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242
Originally Posted by nick62087 View Post
If you can weld and aren't afraid to take a chance, I'd say try it - someone's gotta do it.
LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE
shdybrady19 is offline
post #2 of 5 Old 04-06-2009, 06:57 PM
JackAysJake
Hey bud, Im sure some people are going to flip out about how tired they are of these questions, but before they do...check the FAQ page. Here is a link directly to the site you need.
http://www.jeepforum.com/forum/f13/tire-size-v-lift-size-chart-134378/
JackAysJake is offline
post #3 of 5 Old 04-06-2009, 07:40 PM Thread Starter
shdybrady19
well like i said, I dont know how much lift it actually is now.
post #4 of 5 Old 04-06-2009, 07:43 PM
SocalWJ
Measure from the center of your hub to the bottom lip of your fender. This should give you an idea on how much lift you have.
Maybe one of the ZJ guys can chime in on what the measurement would be stock so that you can compare.
John
'04 Laredo 4x4 select-trac 4.0L
2.5" BB w/ MX6 shocks
Addco Rear sway bar w/ IRO extended links
SocalWJ is offline
post #5 of 5 Old 04-06-2009, 08:22 PM
CrazyWalnut13
That's assuming he hasn't cut the fenders at all.
And OP, quick search just turned up that stock ZJ suspension H to F measurement is about 18", so you just need to go out and measure from the center of your hub straight up to the edge of the fender, then subtract 18" from whatever you get.
Do this at all 4 corners.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
what size tires can i fit on my 04 wj bcthoma ZJ Grand Cherokee Forum 2 10-10-2008 01:53 PM
what size tires? asessa ZJ Grand Cherokee Forum 1 07-01-2008 10:35 AM
What size tires?? redrubi04 ZJ Grand Cherokee Forum 4 09-10-2006 09:00 PM
What size tires? Swiggs ZJ Grand Cherokee Forum 5 07-18-2005 10:50 AM
what size tires do i need to ask for? nineseventhree ZJ Grand Cherokee Forum 2 06-01-2003 10:38 PM
