What size socket do you need to undo front wheel hub nut? - JeepForum.com
post #1 of 19 Old 11-09-2008, 06:21 AM Thread Starter
Bulldoggy
As the title says i need a socket to remove the nut is it 1 3/8" or 36mm.
Thanks
Dave
Bulldoggy is offline
post #2 of 19 Old 11-09-2008, 06:39 AM
limitedman
36mm is the size you need.
limitedman is offline
post #3 of 19 Old 11-09-2008, 06:43 AM Thread Starter
Bulldoggy
Thanks mate
post #4 of 19 Old 11-09-2008, 12:12 PM
COLDFEAR
your gonna need a torc wrench and a cheater bar for that too.
95' GrandCherokee 5.2L V8
3" Pro Comp lift, 33"s, FlowMaster Super 40
COLDFEAR is offline
post #5 of 19 Old 11-09-2008, 12:26 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Please don't use a cheater bar on a torque wrench. Or ever use a torque wrench to loosen a bolt. Doing either is a guaranteed way to damage the torque wrench or at the very least, de-calibrate it.
Use a cheater bar on a BREAKER BAR and then use a torque wrench to tighten it. 175 ft-lbs is the spec.
billzcat1 is offline
post #6 of 19 Old 11-09-2008, 05:29 PM
10achik
I ate what?
10achik's Avatar
^ What he said
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #7 of 19 Old 11-09-2008, 08:43 PM
mailforjon
mailforjon's Avatar
2005 WK
hopefully he meant IMPACT wrench, not a torque wrench.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #8 of 19 Old 11-09-2008, 08:54 PM
magnumcherokee
1992 XJ Cherokee
I think he meant a cheater bar to take it off and a torque wrench to tighten it with. Just the way I read it. That would be correct any way.
92 XJ sport 4.0L HO auto 231 Rustys 4.5"(gained 5") SA lift, ROR Adj TB, AR23 wheels, 33x12.50 MT Baja MTZs, doorless when sun shining
magnumcherokee is offline
post #9 of 19 Old 11-09-2008, 11:33 PM
COLDFEAR
i figured it was a given. maybe not?
COLDFEAR is offline
post #10 of 19 Old 11-09-2008, 11:47 PM
-Joe-
-Joe-'s Avatar
a cheater bar is what you put on the breaker bar/socket wrench to give you more leverage.. Thats what confused people.. 2 different tools if you will.. IE.. You could use a cheater bar on a breaker bar to give you hellish leverage..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #11 of 19 Old 11-10-2008, 10:16 PM
anticrombie
anticrombie's Avatar
Or use an impact gun, it's the easy way. Haha.
Charlie
anticrombie is offline
post #12 of 19 Old 11-11-2008, 09:39 PM Thread Starter
Bulldoggy
Ok guys i just got the hubs ordered and got the socket will be doing it friday.
The hubs do they come off easy or are they a pressed on job? EG will i be able to do it with my normal tools or will i need a press to get them off and on?
I understood what the first post meant was to use a breaker bar and torque them up so all will be good unless i need a press.
Cheers Guys
Dave
post #13 of 19 Old 11-11-2008, 10:03 PM
ajmorell
ajmorell's Avatar
If you are having difficulty separating the hub (usually an issue if it is corroded at all), thread back in one of the 3 bolts and use it to pound off the hub. I've used that method several times with no problems.
ajmorell is offline
post #14 of 19 Old 11-11-2008, 10:23 PM
welchct
1 7/16" works too for thoes who wanted to know.
ORS
Off Road Specialties
welchct is offline
post #15 of 19 Old 11-12-2008, 08:54 AM
BigDaveZJ
If the hubs are going to be replaced, you can just pound the hell out of o the hubs too.
95 ZJ with lots of stuff
14 WK2
BigDaveZJ is offline
socket size front seal np231 zj95 ZJ Grand Cherokee Forum 2 07-12-2009 11:59 AM
socket size ? Nemo04660 ZJ Grand Cherokee Forum 3 06-21-2008 07:54 PM
WJ D44 Pinion Nut Socket Size? cheapjeep2x ZJ Grand Cherokee Forum 7 06-12-2008 08:24 AM
Replacing the front pass. side CV half shaft. What size 12 point socket? Zoso ZJ Grand Cherokee Forum 7 11-07-2007 12:49 PM
socket size Slamm36 ZJ Grand Cherokee Forum 13 06-01-2006 11:17 PM
