what size lift - JeepForum.com
post #1 of 9 Old 09-15-2003, 03:47 PM Thread Starter
coops1105
what size lift
I am looking to get some 31 inch tires for my grand and i also want a lift. I dont know much about lifts so how many inches would you recommend and would you go w/ the suspension lift or body?
99 gc limited w/ I-6
coops1105 is offline
post #2 of 9 Old 09-15-2003, 04:20 PM
crash98
I have I guy I put 24in rims on is grand and we only had to do minor fender triming. haha ( this is for real) for 31's they say you only need like a 2-3 in SUSPENSION not body lift.
crash98 is offline
post #3 of 9 Old 09-15-2003, 04:26 PM
Beachead19
Beachead19's Avatar
Yea can't do a body lift on a ZJ or WJ cause they are unibody. Get a 2 inch budget boost for 31's.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #4 of 9 Old 09-15-2003, 04:43 PM
Big Grand
Junior Member
Big Grand's Avatar
a 2in BB will rub with 31s. 3" lift is needed to run 31s
Big Grand is offline
post #5 of 9 Old 09-15-2003, 05:34 PM
Beachead19
Beachead19's Avatar
Here is a thread from JeepsUnlimited: 31's will fit with a 2 inch bb. http://www.jeepsunlimited.com/forums...light=275%2F70
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
post #6 of 9 Old 09-15-2003, 07:30 PM
JAURS
I used a 3" Skyjacker lift to run 31's. I still experienced some tire rub around sharp turns and when parking but it disappears after around 1000 miles are on the tires. Good Luck.
JAURS is offline
post #7 of 9 Old 09-16-2003, 06:21 AM
Skyjacked97ZJ
You can actually fit 31's stock. Or you could use a 2" lift. Or if you don't want to touch your fenders you could go 3". I'd throw 'em on stock and cut my fenders personally. Im lifted 2" and run 33's.
Skyjacked97ZJ is offline
post #8 of 9 Old 09-18-2003, 04:19 PM Thread Starter
coops1105
how bout 33s with a 3 inch lift?
post #9 of 9 Old 09-18-2003, 10:11 PM
Skyjacked97ZJ
Yeah, that works too, but you still need to hack at the fenders a bit.
Not sure what tire/lift size is right for me. mitchconley ZJ Grand Cherokee Forum 2 11-15-2009 03:37 PM
285/75/16 vs 265/75/16 on 4in of lift with a WJ. what size should i go with? PJNovinskee27 ZJ Grand Cherokee Forum 16 02-18-2009 10:56 PM
Tire size match to lift size zjeepin ZJ Grand Cherokee Forum 5 09-04-2005 12:26 PM
Tire Size v. Lift Size Chart Meerkat ZJ Grand Cherokee Forum 10 02-01-2005 04:56 AM
lift = tire size? 2000gcherokee ZJ Grand Cherokee Forum 2 06-24-2004 07:15 AM
