what size injectors are stock for 94ZJ? Are '94'95 injectors the only ones i can use - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > what size injectors are stock for 94ZJ? Are '94'95 injectors the only ones i can use
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-09-2009, 03:18 PM   #1
hvywt77
1994 ZJ
i have a 94 ZJ with 134K hard miles on it 4.0L. it has a miss at idle. i unplugged injectors and found miss to be on 2nd cylinder. i pulled second plug and i have spark, the cylinder is dry and white so I do not suspect any valve issue. I think the injector is bad/clogged whatever. I can see from online parts store that i am looking for 94-94 4.0L injectors...$86 reman from parts store.
i know there are some reman ones on ebay.
here are my questions:
-what are the specs on the stock injectors? 19lbs? 34lbs?
-can i use comparably rated bosch style injectors out of say a ford car or something?
i am really trying to get by on the cheap and want to know what stuff i can use that i may have laying around...i appreciate your thoughts...
hvywt77 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2009, 03:55 PM   #2
rugermack
If you want to get by cheap go to the junk yard.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote Quick reply to this message
Unread 09-09-2009, 03:57 PM   #3
ratmonkey
R.I.P.
ratmonkey's Avatar
fords work, but are rated at 39psi while the jeeps are 49psi. jeep uses roughly 19lb/hr injectors in all zj's. there's some variation year to year. i'm pretty sure this is all in the faqs.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 09-09-2009, 04:11 PM   #4
LordHobbit
For a stroker, a writeup I have says use 24 lb/hr Accel injectors. Doubt they're cheap though. sorry no part numbers or model numbers, just accel.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline   Reply With Quote Quick reply to this message
Unread 09-09-2009, 04:25 PM   #5
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Compliments of Dino Savva, 39 and 49 psi injectors don't interchange, and all 96-98 V8 and I6 injectors are the same. 4.7HO injectors flow the most, followed by 95 V8.
2.5 I4:
'87 #83502578 ?
'88-'90 #83504851 ?
'91-'95 #53007232 ?
'96-'98 #53030778 23.2lb/hr @ 49psi
3.7 V6:
'02->> #53031099 24.0lb/hr @ 49psi
4.0 I6:
'87-'90 #53003956 18.6lb/hr @ 39psi
'91-'93 #33007127 21.0lb/hr @ 39psi
'94-'95 #53030343 21.0lb/hr @ 39psi
'99-'01 #04854181 22.5lb/hr @ 49psi
4.7 V8:
'99-'02 #53030842 22.5lb/hr @ 49psi
'02 HO #53032145AA 25.8lb/hr @ 49psi
5.2 V8:
'93-'94 #53007809 22.7lb/hr @ 39psi
'95 #53030262 24.6lb/hr @ 39psi
5.9 V8:
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread 09-09-2009, 04:31 PM   #6
rm2001wj
You can use this chart.
4.0 I6:
A '96-'98 23.2 lb/hr @ 49 psi injector would flow slightly less than 21.0 lb/hr @ 39 psi so you could use '96-'98 injectors if you wanted to as long as they fit.
rm2001wj is offline   Reply With Quote Quick reply to this message
Unread 09-09-2009, 04:35 PM   #7
HighLonesome
I guess they do interchange if you know enough about injectors. I have a set of 8 I want to get rid of. PN 53030778 from a 98 5.9. PM if interested.
Unread 09-23-2009, 08:59 AM   #8
hvywt77
1994 ZJ
i got a used injector off ebay. piece of cake. took away the stumble. on to other problems...the guy has a couple more still for sale $9.99 shipped. here is a link
http://www.jeepforum.com/forum/f191/...ipping-862785/
1994 Grand Cherokee 4.0 grey stock
1993 Grand Cherokee Limited Red 4.0 (SOLD)
Unread 09-23-2009, 10:45 AM   #9
frankie_b11
How difficult is it to change these out. I have a 97 grand with 153,000 that I am sure could use some new ones.
Thanks
frankie_b11 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2009, 11:18 AM   #10
impuresoul2k3
53030778 - Magnum 2.5, 3.9, 4.0, 5.2, 5.9L & 2.4L Injector - 1994-2002
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline   Reply With Quote Quick reply to this message
