What should I do with this ZJ? - Page 3 - JeepForum.com
post #31 of 55 Old 04-25-2013, 01:48 AM
LunaMoona
Careful about using a 318 that isn't from another ZJ. The starter is in a different location and may give you issues.
LunaMoona is offline
post #32 of 55 Old 04-25-2013, 06:17 AM Thread Starter
Trick440
1994 ZJ
O really. Shiit. I better make sure the starter is in the right spot. This would be a bummer.
Trick440 is offline
post #33 of 55 Old 04-25-2013, 07:10 AM
PolkaPower
The starter on the Dodge truck motors is on the opposite side. It take a lot of fab to make it work.
PolkaPower is online now
post #34 of 55 Old 04-25-2013, 07:21 AM Thread Starter
Trick440
1994 ZJ
What the hell I thought a 318 was a 318! I have been Googling this and can't find much on the subject.
Trick440 is offline
post #35 of 55 Old 04-25-2013, 07:35 AM
nickpequignot
The accessories on the dodge are on the opposite side. The accessories from the zj should bolt right to the motor and work fine
nickpequignot is offline
post #36 of 55 Old 04-25-2013, 07:43 AM
PolkaPower
Transfer case bolts up at a different angle too so it might not work with the cross member. Other than all that it's the same.
post #37 of 55 Old 04-25-2013, 07:52 AM
dnuccio
If you use the jeep transmission it will be fine. The starter bolts to the trans, not the engine.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #38 of 55 Old 04-25-2013, 08:11 AM
PolkaPower
Yep that's true. Never mind all that other stuff.
post #39 of 55 Old 04-25-2013, 09:38 AM Thread Starter
Trick440
1994 ZJ
This guy...
And especially this guy... , heh.
GET THE HELL OUTTA MY THREAD WITH YOUR MISINFORMATION! Come in here and poop on my parade! You know I ain't good at this stuff. You sons of a .......!
heh jk guise.
Trick440 is offline
post #40 of 55 Old 04-25-2013, 09:46 AM Thread Starter
Trick440
1994 ZJ
Negged and reported.
Trick440 is offline
post #41 of 55 Old 04-25-2013, 10:01 AM
PolkaPower
Just make sure it's a non egr OBDII and swap all the stuff over. Should bolt right up. I believe the Dodge v8's use different exhaust manifolds and motor mounts so you may have to use the ZJ ones.
What does he mean by "high performance motor" exactly? Are you going to need a custom PCM or tune to manage it?
post #42 of 55 Old 04-25-2013, 01:14 PM
speedbucket
Lol
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #43 of 55 Old 04-25-2013, 02:36 PM
dnuccio
go home polka, you're drunk.
R.I.P. Ratmonkey
dnuccio is offline
post #44 of 55 Old 04-25-2013, 03:19 PM
PolkaPower
Here is a Mall Crawlin 5.2 to 5.9 Durango swap. After you get past the homo jokes there is some tech info too. http://mallcrawlin.com/forum/showthr...light=5.9+swap
Quote Originally Posted by Grandsrus
Looks awesome!!!!
I have a couple of questions:
Did you get the 5.9 from a 5.9 Grand or just a Ram truck?
Did you have to do anything special with the balancer? I heard the 5.2 is different than the 5.9 in that respect.
Any other problems you ran into?
Very good job!
Good question... The Harmonic Balancer came with the 5.9 motor... use it only, the pulleys from the 5.2 were a direct swap. Also, the Flex Plate must be used from the 5.9 since the 5.9s are externally balanced.
I scored the motor from a 2000 Durango with 40K on it. Its almost all the same as any 5.2/5.9 ZJ. Exceptions are Obvious (EGR on some years) Oil pump has a longer pick up tube than the Jeeps and oil pan has a bulge at the front and thin in the center to clear the IFS Dodge front ends. SO swaping oil pump/pan is a must. The accesory brackets are the Exact same mounting, as well as timing cover etc. I used the 5.9 Distributor only cuz it was covered in oil like my 5.2 version, other wise the same exact part.
As for harness' the ZJ sensors did not match the sensors on the Durango. ie Crank Position sensor (I think) had 2 wires, where dodge has 3. But thats how many of the sensors were, including the Oil Pressure Sending unit, and Temp sending unit.
Its a pretty easy swap for a 5.2 to 5.9 but otherwise I imagine it being a BEAR going from anything else.
post #45 of 55 Old 04-27-2013, 08:26 PM Thread Starter
Trick440
1994 ZJ
Used an inspection scope to check the cylinder walls and it looked great. Turned it over without any resistance. Everything looked real good on this motor. Asking $400, got it for $370. Its now sitting in my garage waiting to be installed. I'll put in at least half a day tomorrow.
On a side note, my buddy who let me borrow his inspection scope, this is his wife's 2002 Rubicon with a 1975 bug body.
http://www.youtube.com/watch?v=c5rKZ...ature=youtu.be
Trick440 is offline
