-   -   What should I do to my 97 laredo? (http://www.jeepforum.com/forum/f13/what-should-i-do-my-97-laredo-1548601/)
203948576 07-13-2013 06:51 PM
I got my first car. A 97 laredo. After I dropped 40$ in gas and fuel injector cleaner, and some other fluids, he finally stopped stalling on me. Now I am in love with the jeep. When I got it I was missing a headlight. I went to the junkyard, and found 2 brand spanking new headlights, still had the tags on them. I stripped that jeep, and rushed home. Now that all the necessities are done, what should I do to upgrade my jeep?
NOTE- anyone else having a problem with water in the passenger floorboard and under the rear passenger seat? I am convinced it is the a/c hose leaking. Also I find that there is not alot of storage room in the vehicle. Any suggestions on how to fix that?
Compgeek789 07-13-2013 08:35 PM
If it is wet while running the A/C then the drain for the evaporator's condensation pan is clogged. This is common for many vehicles. Try to power wash the undercarriage under the front passenger area at the car wash to make sure no mud is blocking it. If still wet underneath you may need to clean the pipe out.
And on storage, I have the same issue. You can either fold the rear seats down, or (this is not recommended) pull the spare out. If you still want to keep a spare in there try to find a compact spare tire.
um7267 07-13-2013 08:52 PM
congrats on the jeep
check your door seals, mine leaks because i ran my sub wiring through the seal
ZeeJay1997 07-13-2013 09:18 PM
the water is most likely going out the tube, then running back in because the seal is rotten.
Read this all the way through, it covers all the bases
coralman 07-14-2013 06:05 PM
Welcome to the forum, alot of good people and info reside here. Clean all your grounds nice and shiny. Anytime you do anything in the electrical arena ALWAYS disconnect the negative battery terminal. Crawl under it and take a look at the suspension and steering. Fill out your profile so we know the specs on your jeep. Give it a tuneup if you haven't already. Check all your hoses. Look at all seals. Change the fluid out in your pwr steering pump. Look for trash in between the condensor and radiator. These will get you started.
JohnnyZJ 07-15-2013 12:02 PM
i'm interested to hear how you came to this very ridiculous conclusion as well as why you think putting the rear seat down is 'not recommended'
as for stuff to do to your new jeep, start with maintenence. new fluids, tune up, replace old worn parts etc. lots of stock maintenence type stuff to do first. then you can throw your money away in modding it.
203948576 07-15-2013 04:24 PM
Cool
I took out one of the rear seats and folded down the seat. Made alot of room. I may take out the other seat considering it is just me driving with the occasional two passengers. No parts need replacing. Only real complaint is the a/c, but I have no problem rolling down the window. I know how to fix the ac, but its a monster to do and I lack the patience at the moment. I'm putting in a new stereo. I may put in new speakers (not sure just yet). I dont really need a lift or anything considering I dont go mudidng. However, I do go wooding alot. (Same thing as mudding but in the woods).
dbmorris99 07-15-2013 04:46 PM
Welcome from another Ga member. for speakers they are 6.5" front an rear. I would definitely look into getting a front and rear skid plate and recovery hooks. I know that the Conley Pull a Part has a ZJ on row 82 that has all 3 of these and you can get them all for $60
203948576 07-15-2013 05:57 PM
Just a few photos of the jeep so yall can give me a few ideas. Just replaced the headlights. That pick apart is where I got these brand new healdights. Only a week old when the car got towed to the junkyard. How lucky can ya get?
203948576 07-15-2013 05:58 PM
Okay apparently my photos are to big. So where can I go or what can I do to upload them?
The time now is 06:22 PM.
