What Schould I DO!!!!! - JeepForum.com
post #1 of 14 Old 09-18-2011, 12:01 PM Thread Starter
millardo21
no sure what to do here is a pic of the door latch on the drivers door. any advise would help the door wont shut all the way
millardo21 is offline
post #2 of 14 Old 09-18-2011, 12:52 PM
nicklopic
Had that happen to me, ill post pics how I fixed it,
Basically used the part that's bent (broke off) spun it to pull the latch into place and a washer atoms the back on to help hold everything in place
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #3 of 14 Old 09-18-2011, 12:56 PM
nicklopic
http://pbr1221.photobucket.com/album...g?t=1316371986
http://pbr1221.photobucket.com/album...g?t=1316371954
I hope it helps, this fix has held for me since march with no problems so far
98' ZJ 4.0
post #4 of 14 Old 09-18-2011, 01:50 PM
somebody5788
1994 ZJ
I'd just have a shop weld it back up real quick. Then just get some red touch up to paint the welds so it doesn't rust
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #5 of 14 Old 09-18-2011, 10:49 PM
canadiandiesel
1994 ZJ
I had bad luck trying to weld the flimsy metal it's already been fatigued just do the washer trick so far it's the best cheap fix and works, increasing surface area for the latch to hold firmly to the door frame
canadiandiesel is offline
post #6 of 14 Old 09-19-2011, 01:59 AM
Oldfrog
2007 WK
Any decent welder can weld that right up. If you were nearby, I'd do it with my wire welder for you...but I'd brace it somehow too.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 14 Old 09-19-2011, 07:15 AM
somebody5788
1994 ZJ
You just need to weld a thin piece of metal on top so that you aren't using the fatigued metal anymore. If you cut a piece that went around the entire latch and had it welded in then I have no doubt it would hold as well and as long as the original.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
post #8 of 14 Old 09-19-2011, 07:43 AM
Technohead
I'd also recommend resizing your images before uploading them. 640x480 is pretty good.
-Eric
Technohead is offline
post #9 of 14 Old 09-19-2011, 07:49 AM
somebody5788
1994 ZJ
It auto re sized for me?? Personally I much prefer the larger photo so you can click to enlarge and actually see what the photo is. But this is what it does for me. Small photo unless I click on it. No need to resize it.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
post #10 of 14 Old 09-19-2011, 08:04 AM
KJK
Fix your worn out door hinges. This door latch issue is a direct result of worn out hinges.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #11 of 14 Old 09-19-2011, 08:09 AM
sadass
2x on fixing the root cause, the door Hinge Pins . I have had that happen to the driver side door on every ZJ I have owned.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #12 of 14 Old 09-19-2011, 08:13 AM
sadass
Check out this link while your at it. its a link dealing with the cause of your door latch issue
http://www.jeepforum.com/forum/f13/d...cement-506080/
sadass is offline
post #13 of 14 Old 09-19-2011, 09:24 AM
airwolf9090
Why not just go to a junk yard and find another red door?
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #14 of 14 Old 09-19-2011, 11:23 AM
BeachRig1
The only proper way to fix this issue is to replace the door and ensure you inspect for wear or replace the hinges you will get with the door. I would replace door and hinges while it was off the ZJ. The symptoms were there every time the door opened and dropped a half inch or more.
BeachRig1 is offline
door , drivers , latch , left
