What's the problem if not the ignition coil? - JeepForum.com
post #1 of 2 Old 03-22-2016, 07:07 PM Thread Starter
EliW0894
I recently read the OBDII codes on my 96 GC Laredo, and it indicated a faulty ignition coil. I just tested my ignition coil, and my multimeter read out a primary resistance of 1.2-1.4 ohms and a secondary resistance of 12,050 ohms. If I'm not mistaken, this is within the acceptable range. So, if the ignition coil is still good, what could the issue be? Here are the codes I got that indicated the ignition coil; P0420, P0351, and P0132.
EliW0894 is offline
post #2 of 2 Old 03-22-2016, 10:49 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Could be a fault in the wiring. The PCM provides a ground to the coil to energize it trough a trigger wire. That might not be your only wiring issue based on the other codes you got.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, Jones Exhaust A3518M-5
rep-tile is offline
