Quantcast What r the best Spark Plugs to buy for a JGC? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > What r the best Spark Plugs to buy for a JGC?
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 05-04-2004, 12:08 PM   #1
KingZeke
Well I am going to change the spark plugs and do the gasket on my differential cover this coming up weekend. What is the best spark plug to buy? Are the splitfires and the platnum 4s as good as people say? Are there better ones? Should I redo the wires too?
[COLOR=darkslategray][FONT=century gothic]1997 Jeep Grand Cherokee Laredo [/FONT]
[FONT=century gothic]2 Inch Budget Boost from Rubicon Express[/FONT]
[FONT=century gothic]31 Inch Tires, Shaved front facia[/FONT][/COLOR]
[COLOR=DarkSlateGray]IMCO Exhaust[/COLOR]
[COLOR=DarkRed]Almighty 2" BB Club Member # 38 [/COLOR]
KingZeke is offline   Reply With Quote
Old 05-04-2004, 12:53 PM   #2
Joseph Humphrey
dont waste your money on the platinum pulgs. or on the over priced champion plugs. get a set of ngk v-power copper core plugs. you should be able to order them through your local auto parts store (napa, autozone, car quest etc...) they chould be about 1.25 each and will work great
you can replace the wires if you want to. most people do. unless you are going to replace the ignition controler with something like the msd or crane cam fireball and the coil, dont get the ultra premium wires. .
The Almighty 2" BB Jeep Club Member #34 (no more BB)
[B]Silver 98 ZJ 4.0 I-6[/B]
K&N FIPK Gen II
JKS Adjustable Track Bars F and R
JKS Adjustable Control Arms
JKS Quicker Disco's
Kevins 3.5" Lift Kit w/ MX-6 Shocks
US Wheel 15x8 10 spoke black Steelies, 31" BFG AT KO rubber
Joseph Humphrey is offline   Reply With Quote
Old 05-04-2004, 12:56 PM   #3
KingZeke
You really think that they are a waste of money? Well I appreciate the input I will have to stop by Autozone today and pick some up. Thanks.
Old 05-04-2004, 02:36 PM   #4
xxxflhrci
I'm a fan of platinum plugs. The electrode takes longer to wear away on them, meaning you get more miles out of them. I just use there regular Bosch Plats or Autolite ones.
xxxflhrci is offline   Reply With Quote
Old 05-05-2004, 10:08 AM   #5
KingZeke
Do you think it is a good idea to use the standard platnum plugs because the engines in these jeeps burn on the hotter side? I have heard that the platnum plugs are good for hot burning engines. What is your take on it folks?
Old 05-05-2004, 10:28 AM   #6
xxxflhrci
Just get proper heat range for your engine.
Old 05-05-2004, 11:45 AM   #7
boilingpoint
Spark Plugs
Hi there,
I have tried several different brands of sparks plugs over the years in my 93 JGC. Im the original owner of my Jeep which now has almost 350,000 KMS on it. So you can see I have replaced my plugs several times.
For my first replacement set I bought the Bosch Platinums. The second set I bought Autolite Platinums. Third set I bought NGK V Power. The most recent set I have returned back to the OEM which is Champion.
From my experience I didnt feel any benefits with the platinums. In my opinion the Champion plugs performed just as well if not better than the rest. I am sticking with Champions from now on.
Oh yeah not sure where Joseph lives but where I live Champion Copper plugs are the cheapest of the bunch. You can buy them for a $1.25 CDN each or less than a dollar US.
boilingpoint is offline   Reply With Quote
Old 05-05-2004, 11:49 AM   #8
greasefingers
1994 ZJ
The heat range of a spark plug is the plugs ability to get rid of heat. They typically do this by changing the length of the plug. So a longer plug takes more time to dissipate heat and is called a Hot plug. I have no idea what heat range jeep uses, so I always use what they recommend. The engine can not get more power from choosing “better plugs”. And obviously, choosing a plug with more than one electrode can not increase the power either.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 05-05-2004, 12:10 PM   #9
jeepme79
Bosch Platinums aren't worth the cost of the cardboard they come in. I put a set in my zj and my wife's intrepid, and in both cars, the electrodes were gone within 6mo. It was so bad in the intrepid that it wouldn't even start. IMO, go with NGK V-Power.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline   Reply With Quote
Old 05-05-2004, 12:14 PM   #10
boilingpoint
Off the topic
Hi jeepme79,
I noticed your are running 245/75-16 tires. Is that on the stock wheels or aftermarket one? Is your Jeep raised?
Thanks.
Old 05-05-2004, 01:29 PM   #11
jeepme79
Stock wheels, no lift yet. I had to trim the little inside corner of the front bumper, and I get a little rub at full turn. They are also 'E' rated, so the ride is a little stiffer. I'm looking for a small lift and going to 265/75 16's next.
Former Jeeps:
89 XJ, stock
Old 05-05-2004, 01:31 PM   #12
thuper
How about asking for the right spark plugs for your engine instead of the car. Knowing the car doesn't help some one answer as well.
Plus 4s are crap.
Another poorly thought out post by me.
[SIZE=3][COLOR=white]White Jeep Club #12[/COLOR] [/SIZE]
thuper is offline   Reply With Quote
Old 05-05-2004, 03:19 PM   #13
Meerkat
If you have the V8, don't buy Champion plugs. In fact, whatever plugs you buy, open one at the store and inspect it. If it requires the large (I can't remember sizes right now) socket, then you won't be able to install it, there isn't enough clearance between the plug and the plug well to fit a socket wrench. Go for the plugs (such as NGK's) that use the smaller sized socket.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Old 05-06-2004, 09:58 AM   #14
KyleM
on 4.0s, some people use the shorter plugs that the 4.0L Cherokees use (at least the ones from the early 90s, I believe). They say using the shorter plugs addresses the pinging issue. I haven't tried them yet. Anyone done this?
KyleM is offline   Reply With Quote
Old 05-06-2004, 10:24 AM   #15
KingZeke
I did the plugs last night. I just used Bosch copper plugs. They were $0.99 and work just great. I was told they they are nicer than the Champion copper and that they were all that I needed.
Glock Forum
