What is the problem? - JeepForum.com
post #1 of 7 Old 04-25-2004, 01:30 PM Thread Starter
badpenny
My '93 Grand Cherokee
will not start--it ran when my wife came home from
> work on Thursday afternoon, and would not start
> Thursday night. I have obtained a Haynes manual and
> have already changed the plugs (to Bosch
> platinums--they are identical to the Champions that
> I removed), plug wires, cap & rotor. All components
> replaced were in need of replacement anyway. Here is
> where my confussion begins: the battery tests at
> 11.9 volts, and the connections have been cleaned,
> the only fault code I can get is for "problem with
> battery connection". To further try to diagnose the
> problem, I've used a new spark plug to ground the #2
> wire to the block--no spark. I did the same with the
> coil wire--spark! I've removed the cap and bumped
> the starter and the rotor spins, the coil wire
> button in the cap appers to be making contact,
> everything appears to be correct. I've tested the
> Auto Shutdown relay and it seems to be functioning,
> tested the cam position sensor and the crankshaft
> position sensor as directed in the manual and they
> appear to be functioning. I forgot to disable the
> fuel pump prior to the first test and can tell you
> that the fuel system smells like it is functioning.
> After all this the only code is "problem with
> battery connection"
> Now here is something to complicate things
> further--EVERY time the driver's door is opened with
> the key in the ignition switch the security alarm
> sounds!! I haven't locked the doors since I started
> working on it 3 days ago. Now I wonder if the
> security system is not allowing the vehicle to start
> somehow. Can this be the case? I am unable to make
> sense of this myself because the diagrams (or the
> rest of the manual for that manner) don't show
> anything about the security system. I'd like to
> avoid taking it to a dealership if I can due to
> labor costs. I hope that I've provided enough info
> for you. Thankyou
badpenny is offline
post #2 of 7 Old 04-25-2004, 03:21 PM
10achik
I ate what?
10achik's Avatar
Nice description of your problem, most just say, it wont start...
It sounds to me like your security system is causing the problem. Im not sure about the 93, but if the alarm is activated the car will not start. Part of a starter kill or something...
This may sound silly, but does your key fob still work, just try to lock it and unlock with the buttons to activate/deactivate it. If that doesn't work I would say that your alarm is stuck in active mode, I can't really help in disarming that, but hopefully someone else in here can.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 7 Old 04-25-2004, 11:06 PM
Meerkat
Actually, the Jeep will start, even with the alarm sounding (personal experience). In fact, the owner's manual says that one way to disarm the alarm, is to drive 35 MPH or faster. I'm pretty sure it has to start to do that.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 7 Old 04-27-2004, 03:34 AM
RockPaws
RockPaws's Avatar
The battery connection code, is due to the battery being disconnected reciently - ok. Have you checked your fuel pressure? Sounds like a possible fuel problem.
Another thought about the alarm, some vehicles I work on, when the battery has been disconnected. You have to turn the key in the drivers door back and forth.... its worked in the past. try it ..
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #5 of 7 Old 04-27-2004, 04:50 AM
LTDunltd
edited for reply;
Buy what you have writen. I take it that when you put a spark plug in the #2 plug wire, you got 'No Spark', but when you put it in the coil wire you got 'Spark'
Now here are the things you need to check;
1)Continuity from the coil tower to the button.
2) Align the timing mark on the crankshaft to TDC. (to make sure you are not out 180 deg. you will have to remove the #1 spark plug and stick a piece of wire in the hole. if you hit the piston your OK, if not turn the crank 360 deg. [one full revolution] ) After that make sure that the rotor is pointing toward the #1 tower. And that the wires are in the right sequence. (I have wired the cap backwards before).
LTDunltd is offline
post #6 of 7 Old 04-27-2004, 07:14 AM
gthaefner
your alarm is going off because there is a broken wire in the door jam that tells the alarm when do disarm when u unlock the door. open the door and look inbetween the hinges and there is a big black rubber tube holding all of the wires going to the door. find the broken one and just splice a new peice of wire into it. about the engine i cannot help u there.
94 ZJ
4.0 I6
NP242 swap
3.5 RE superflex with adj. arms
adj. trac bars
31s for Now
LOWERED CARS ARE FOR PEOPLE WHO CANT GET IT UP
gthaefner is offline
post #7 of 7 Old 05-11-2004, 09:51 PM Thread Starter
badpenny
Thanks For Your Help...problem Is Fixed
Thank you to everyone who responded! After much frustration, we broke down and had the Jeep towed to our local dealer....the problem was the coil wire. So $219.00 later, it is fixed and running fine. Of course, a week later, the dealer got another $300.00 out of us when the ignition went bad!...But that was something that noone could have forseen. Flange broke, had to be replaced and electronically reset. But is better now...so thanks again all. We know where to come when problems arise!
badpenny is offline
is this a battery problem or alternator problem? Lady_Luck ZJ Grand Cherokee Forum 14 01-02-2009 09:04 AM
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 03:00 AM
Problem with the wheel staus lights on dash and head light switch problem jeep2dmax ZJ Grand Cherokee Forum 0 12-21-2007 08:34 PM
HELP! SOS! 94 GC overdrive problem-Will VSS solve problem tinker1121 ZJ Grand Cherokee Forum 1 07-15-2005 10:08 AM
'93 Starting Problem,,, PCM Problem? jeff_connors ZJ Grand Cherokee Forum 0 01-19-2004 11:53 AM
