What Manual do YOU use? - Page 2 - JeepForum.com
View Poll Results: What Service Manual do you use?
Haynes 18 43.90%
Chilton 2 4.88%
Chrystler 13 31.71%
Online 2 4.88%
Ask the Forums 6 14.63%
Voters: 41. You may not vote on this poll
post #16 of 21 Old 06-24-2013, 01:39 PM
kg6mov
Hears the voices
kg6mov's Avatar
9er has a different trans than any other zj, maybe it was the number for the 5.2
Sent from my iPad Nano using JeepForum
kg6mov is offline
post #17 of 21 Old 06-26-2013, 12:15 AM
AVR2
I could be wrong here, but doesn't say Haynes say to add four quarts as a first step, and then run the engine, shift through all the gears, put it into neutral and then check the dipstick and top up bit by bit until it's at the correct "cold fill" level? And then check it again for the hot fill level after you've driven it to warm the trans up to normal operating temp?
AVR2 is offline
post #18 of 21 Old 06-26-2013, 05:17 AM
98ZJOKC
Originally Posted by AVR2 View Post
I could be wrong here, but doesn't say Haynes say to add four quarts as a first step...
Well, actually it says to add two quarts as a first step, but your point is well taken and a reminder to always RTFM and follow the steps to the end.
98ZJOKC is offline
post #19 of 21 Old 06-26-2013, 08:19 AM
WhiteOut
WhiteOut's Avatar
Haynes only for torque specs.
WhiteOut is offline
post #20 of 21 Old 08-04-2013, 08:18 AM Thread Starter
eagsc7
1994 ZJ
Anyone else?? I'm sure that there's more than 37 of us that use a manual.
eagsc7 is offline
post #21 of 21 Old 08-04-2013, 09:39 AM
newfieZJ
I use a combination of FSM, Haynes (the photos can be more useful than the illustrations in the FSM) and the forum. Seems the most sensible way to do it. Ideally, your poll needs a "combination of these" option to fully cover all the bases.
For best illustrations , get the Factory parts list . FSM ain't that good for pics
Factory Service manual , parts list are my go to references .
newfieZJ is offline
