what lift? - JeepForum.com
post #1 of 4 Old 09-01-2003, 01:12 AM Thread Starter
asuseth
what lift?
This is my first post on the site here, and i just recetly bought a 97 jeep grand cherokee laredo and I love it. i am wanting to put a nice lift on it so i can fit comfortably 32's and maybe even a 33. Wanted to simplyy get you guys opinion about which lift is better than some others and what to stay away from. Let me know guys a nd it would be greatly appreciated. Tlak to you guys soon. Thanks agian.....seth
asuseth is offline
post #2 of 4 Old 09-01-2003, 03:08 AM
Swamp Boy
Swamp Boy's Avatar
You will need at least a 4.5 to get 32's and you will need to trim fenders and front bumper for 33's Even if you put a 5.5..
If it where me I would go with a 3.5 (Rubicon Express is good)
and Just trim a little for the 32's .. If you go higher than 4 you run into all kind of problems.. Adjustable trackbars , new driveshafts..
longer brake lines. Etc. etc... See you will open yourself up for alot of money.. Just to fit 33's and you will still have to cut...
good luck with whatever you decide...
By the way.. YOu can get a 2" budget boost and fit 31's
that should get you into some stuff.. And a BB only cost around $100 ish.. Compared to the 12-1500 for a 5 inch..
Look around and see how much you are willing to spend ..Then decide what you want from there.
Like I said ..... Good luck.. Lots of decisions..and tons of money...
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 4 Old 09-01-2003, 11:39 AM
demtjcj
i have 6.5"s with no sye, no new driveshafts. but it all depends. the RE is very good. yeah you spend some money but its worth it. i know that you can fit 32s with 3.5"s, but you have to trim the front bumper. i have 6.5" with 33s and had to trim the front bumper. the reason you have to trim so much is because the wheel wells are like and upside down U. so therre is not room on the sides. hope this helps
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #4 of 4 Old 09-02-2003, 02:07 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'm running 6.5 and 33s. At 4.5 you can run 32s.
I'll post some pics for you.
Hunter
4.5 and 32s
6.5 and 33s
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
ZJ Front to rear lift How much lift should i expect? jeep95xj ZJ Grand Cherokee Forum 30 02-08-2015 07:00 PM
BDS 2" Lift vs. Budget Boost lift csi ZJ Grand Cherokee Forum 14 04-20-2009 02:26 PM
iron rock offroad 4.5 premium lift, or rubicon xpress 4.5 lift? jeepheller98 ZJ Grand Cherokee Forum 22 02-08-2009 09:34 PM
lift question. thinking of going bigger and now i am slightly confused about old lift Irish_Assassin ZJ Grand Cherokee Forum 12 01-22-2009 01:17 PM
Max towing with lift/trail blazer lift s2gots ZJ Grand Cherokee Forum 6 11-03-2006 06:00 AM
