what is this leaking? (pics) how hard is it to fix? - JeepForum.com
post #1 of 7 Old 07-15-2003, 10:08 AM Thread Starter
nineseventhree
how hard of a fix is it? can i do it or a mechanic must? thanks!
nineseventhree is offline
post #2 of 7 Old 07-17-2003, 02:27 PM
automan25
A. What are the specs on your jeep?
B. You should really use jackstands before you crawl under your Jeep.
The underside of your Jeep looks a bit different from mine. I don't recognize that rounded metal pan thing. The part that appears to have a hole in it. The pan in front of it, above the exhaust pipe is obviously the oil pan, and the one behind is the transmission pan. I'm stumped.
The fluid could really be oil, trans fluid, or PS fluid. It could be flowing down from higher up on the engine.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #3 of 7 Old 07-18-2003, 06:49 AM
scubatch2
if its tranny fluid then it could be thr seal for your converter.Mine did the same thing,about $3-400. If its oil then it could be your rear main seal, not sure how much to fix.It is hard to tell with pic's but if you can let us know if its tranny fluid or oil you may get better response.
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #4 of 7 Old 07-18-2003, 09:19 AM
1st jeeper!
Rear main seal. Mine is leaking quite badly right now.
Visit
to see some high school students build robots for a learning experience!!
1st jeeper! is offline
post #5 of 7 Old 07-18-2003, 04:31 PM Thread Starter
nineseventhree
how much is a rear main seal to get fixed?
post #6 of 7 Old 07-18-2003, 10:46 PM
1st jeeper!
yourself - $50 + any type of beer/drinks
Mechanic - upwards of $300+
Visit
post #7 of 7 Old 07-27-2003, 03:06 PM
PDshooter
What color is the fluid?
Is this a 4.0 engine? could be the back of the valve cover leaking oil!
If its muddy looking it could be coolent?
96 GC 117K 4.0
Sele-Trac
Retired guard 20yrs
MOS 63H 11B 43E
PDshooter is offline
Hard idling, sometimes hard to get going JackieChilesEsq ZJ Grand Cherokee Forum 18 01-12-2010 11:49 AM
How hard is it to replace hard brake lines in '01 WJ? Crewdude007 ZJ Grand Cherokee Forum 1 04-06-2009 08:56 AM
Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! Soft 8 WJ Grand Cherokee Forum 11 02-02-2009 05:10 PM
ZJ..Leaking water and oil....HELP...*PICS* -cAcHe- ZJ Grand Cherokee Forum 10 02-04-2008 12:36 PM
04 WJ Hard to Engage 4wd and Hard downshift jake4177 WJ Grand Cherokee Forum 4 07-25-2007 06:35 PM
