What Kind of Front Drive Shaft/Lift Kit ? - JeepForum.com
post #1 of 8 Old 02-14-2005, 09:11 PM Thread Starter
Bosshound
Now that I am going to Replace my Front Drive Shaft I thought to myself WHY NOT lift the Truck ? I think a 4 Inch lift would do . The question is what kind of Lift is Recommended ? and where do I get one ? Should I attempt this Myself or should I get a Professional ? Can I still do 90MPH with a 4 Inch Lift ? Before People Flame me for Driving TOO FAST !! I do Drive Safely and only Drive Fast on Open Roads in the Right Weather Conditions !
CHEERS !
Bosshound is offline
post #2 of 8 Old 02-14-2005, 10:03 PM
mr_user
I'm not the lift specialist by any means on this forum, but 4" is a pretty substantial lift. I am pretty sure that you will need a slip yoke eliminator to reduce driveline vibes amond other things, but maybe not. Hunter?
Also, once you get a lift that high, new (very big) tires are inevitable if you do not want to look extremely awkward. The mods will never stop, and it can reallyyy hurt the budget. More power to ya though!
As for the 90mph, with my stock height 30x9.5" ZJ, 90mph seems a little shaky..I couldn't imagine it with 33's or 4.5" of bump.
Matt
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #3 of 8 Old 02-14-2005, 10:12 PM
laxwarriors21
laxwarriors21's Avatar
I have 4.5'' and 32'', I made it to 90mph and I am still alive
--4.5'' RE Lift
--31'' x 10.50'' Firestone Desination MT's
--Trail ready bumpers
--Conferr roof rack
--Two Hella Model 500 driving lights
laxwarriors21 is offline
post #4 of 8 Old 02-14-2005, 10:20 PM
mr_user
I don't think you will need the SYE after all. However, I found some useful information for you thanks to LouisianaZJ over on JU.
For a 4.5" lift, you'll need
steering stabilizer
adj LCA's
adj front t-bar
adj rear t-bar or bracket
longer swaybar links front
shocks
longer brake lines front
bumpstops f/r for 32's or 33's.
Also, death wobble becomes prevalent at such heights and you will be taking a risk. Do you do a lot of wheeling, or is this just for looks?
mr_user is offline
post #5 of 8 Old 02-14-2005, 10:21 PM Thread Starter
Bosshound
You mean 4 inches is Too High ? I can Settle for a 2 Inch Lift. Thanks for all the Info !!!
post #6 of 8 Old 02-14-2005, 10:22 PM Thread Starter
Bosshound
Very Little wheeling. Mainly for Looks
post #7 of 8 Old 02-14-2005, 10:31 PM
matt.x
matt.x's Avatar
"too high" is relative to the person, the budget, and the expected driving type. not wanting to go offroad = looks ... so determine what size tire you want and lift accordingly ... the purpose of a lift it to fit larger tires (with the smallest lift possible). See http://www.kevinsoffroad.com/zj/zjlifts.html for an idea (if you have a ZJ - 93-98)
HTH
Matt
Red Jeep Club Member #237
matt.x is offline
post #8 of 8 Old 02-14-2005, 11:43 PM Thread Starter
Bosshound
Sorry !
I have WJ 2002 Jeep Overland 26,000 Miles
I Broke the Rule that I used to Always Get Pissed about other Peoples Threads. No Year Make and Model !!!
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 10:53 AM
Stock single/double front drive shaft, 4.5" lift the88thpianoman ZJ Grand Cherokee Forum 14 10-30-2009 09:41 PM
Front Drive Shaft Problem with lift kit KDXFreestyle200 ZJ Grand Cherokee Forum 3 09-12-2009 08:28 PM
distroyed cv front drive shaft after lift did I do somthing wrong sadass ZJ Grand Cherokee Forum 1 06-28-2008 07:04 PM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 10:17 PM
