What is this hose(s) called? - Page 2 - JeepForum.com
post #16 of 18 Old 04-13-2011, 06:17 AM
newfieZJ
Don't forget , double clamp both ends , hell , tripple clamped em , but yes , that's exactly what to do . And , make sure the rubber line is specically trans line , it's oil resistant . Rubber line will swell and leak .
newfieZJ is offline
post #17 of 18 Old 04-13-2011, 08:53 AM
Obie95Sahara
Originally Posted by BlueDevil View Post
OK, I can't seem to find the transmission rubber hose online. And I don't know the dia, too
Any input? Thanx!
EDIT:
Of course - found it the moment I posted
So, is it better to take this hose and cut the hard lines, or maybe easier to take two of these (and if so, what's with the metal-tube-part? I thought I'd get just the rubber hose with connectors, and that it's as easy as disconnect-reconnect )
That hose is EXACTLY the hose you wanna buy, that's what I got for mine and the diameter is correct.
You need the metal line to still come off the tranny as well as the radiator. Do what we've told you to do, which is cut the metal lines after the fittings. You're only replacing the rubber hose, by cutting it this way only the rubber hose will be removed. Slide the new rubber hose over both ends of the metal line (about 3-4 inches) and clamp in on... Takes 15 minutes, if that.... Simple fix.
Obie95Sahara is offline
post #18 of 18 Old 04-14-2011, 12:33 AM Thread Starter
BlueDevil
Tube ordered. Will be cutting the lines as suggested. Thanx again, this is one great forum!
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
