What is this hose(s) called? - JeepForum.com
post #1 of 18 Old 04-12-2011, 10:35 AM Thread Starter
BlueDevil
I have a small dripping at this hose/hoses. It's from the tranny, going towards the front radiator (I don't have the heavy-duty cooler that came with towing package).
What's the name of those, or do I need just the connectors because hoses seem in very good shape?
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #2 of 18 Old 04-12-2011, 10:55 AM
Obie95Sahara
Those are the transmission lines. They go into the radiator so the radiator can cool the transmission fluid. You're going to need new lines (dealer part) or you could splice the lines with new rubber hose. Advanced and autozone carry the transmission hose made for re-locating a transmission cooler. That stuff should work.
Obie95Sahara is offline
post #3 of 18 Old 04-12-2011, 11:07 AM Thread Starter
BlueDevil
I belive the leak is on the rubber hoses, not the hard lines. So I need just those hoses? And what about connectors? I can't seem to locate those at rockauto.com
post #4 of 18 Old 04-12-2011, 11:15 AM
no5son1962
Is it trany fluid on the hoses or antifreeze? In the second picture it looks a little green like anti freeze. Maybe it is the lighting that makes it look green.
95 ZJ 4.0L 3 inch Lift
99 XJ 4.0L 4 inch Lift
no5son1962 is offline
post #5 of 18 Old 04-12-2011, 11:18 AM
Obie95Sahara
The only way to tell is to get under it, wipe the lines down & with it running see where it is leaking from.. From my experience it will leak from the metal fittings most of the time. The rubber hose could be dry rotted as well though. If thats the case just get some rubber transmission cooler line, it comes in a 6ft. package at advanced for like $8.00 or something, and some hose clamps to fit the new rubber line. Cut the old rubber hose off the metal line, and replace with new rubber hose & clamps. Shouldn't take more than 15 minutes. I did this with mine a couple months ago as mine were leaking, and now not a drip
post #6 of 18 Old 04-12-2011, 11:29 AM Thread Starter
BlueDevil
Reddish - so it's tranny lines. And I belive it's on fittings cos above the fitting (towards the cooler, not shown on photos) it's dry, as well as the bottom part of hoses. I think it's leaking right from the fitting but those towards the cooler.
So, what are those fittings called? For the hose I got the name: rubber transmission cooler line. But fittings?
post #7 of 18 Old 04-12-2011, 11:35 AM
Obie95Sahara
You're talking about the fittings right where it goes from metal line to rubber hose right? If you are, I cut mine on both ends with a tubing cutter about an inch above those fittings and just clamped on the new rubber hose. Those fittings are for how the factory hose is made. I thought maybe I'd have a problem with it leaking, but it hasn't leaked one drop the way that I fixed it.
post #8 of 18 Old 04-12-2011, 11:39 AM Thread Starter
BlueDevil
You cut the hard line? And then just slided rubber hose over the hard line, with the ring-thing on top to keep it all together?
post #9 of 18 Old 04-12-2011, 11:43 AM
Obie95Sahara
Yup, I cut the hard line about an inch above those fittings on each end. Then I slid the new rubber hose onto the hard line about 4 inches on each end, and clamped both ends tight. Worked for me.
post #10 of 18 Old 04-12-2011, 11:54 AM Thread Starter
BlueDevil
Great!
And what about the air that gets in with new tube? Need to get it out or?
post #11 of 18 Old 04-12-2011, 12:01 PM
Obie95Sahara
No issues with air... It didn't shift any different or anything when I was done. I could be wrong, but I don't think that the tranny lines are like the brake lines or power steering lines. Even when I replaced my power steering lines I didn't need to bleed any air out, just turning the wheel back & forth did that. So I'm going to say no to the air issue. But if someone knows something I don't hopefully they will chime in.
post #12 of 18 Old 04-12-2011, 12:08 PM
MaintMech
Old and in the way
MaintMech's Avatar
No need to worry about the air. The trans will burp itself as you drive. Just check the fluid levels after a few miles and top it up.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #13 of 18 Old 04-13-2011, 01:46 AM Thread Starter
BlueDevil
OK, I can't seem to find the transmission rubber hose online. And I don't know the dia, too
Any input? Thanx!
EDIT:
Of course - found it the moment I posted
So, is it better to take this hose and cut the hard lines, or maybe easier to take two of these (and if so, what's with the metal-tube-part? I thought I'd get just the rubber hose with connectors, and that it's as easy as disconnect-reconnect )
post #14 of 18 Old 04-13-2011, 04:04 AM
newfieZJ
Just cut the steel lines about 4-5" from the rad (where it points toward the ground), then cut the hose just before the connection at the disconnect .
You need a specific rubber line made for transmissions , then join the 2 with the rubber hose and double clamp both ends .
You've just removed the check valve , one of the leading causes of transmission failure in Mopars IMO , congradulations .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #15 of 18 Old 04-13-2011, 05:48 AM Thread Starter
BlueDevil
OK, let me get this right: I cut the steel lines (with a tube cutter) towards the radiator, on the point where they point straight downwards. Then I cut the steel lines on the tranny-side, like an inch from the connection with rubber hose. That way the rubber hose remains with some steel lines attached at both its ends. And then I slide the new rubber over the steel lines to replace the cut parts, clamp both ends, and I'm ready to roll.
Is that right?
