What have you broken on your ZJ - Page 3 - JeepForum.com
post #31 of 46 Old 06-21-2012, 08:47 PM
GuydeLoimbard
Originally Posted by mrclark25 View Post
how? lobe worn off?
Not worn off per se, but there were chunks missing from 3 of the lobes.
GuydeLoimbard is offline
post #32 of 46 Old 06-21-2012, 09:06 PM
hdrocknroll
This is a, copy n past, parts, repairs, some items duplacated, some not yet added.
I purchased my 95 grand Cherokee 4.0
.265,000 Mi. Dec 3 2011, Worked
on it almost every day for 18 days This
is my check list of to do repairs that
have been finished [X] Back seat stuck,
unbolt and reassemble [X] Cleaned PCM
harness plug with contact cleaner,other
connectors,also [X] Check trouble codes
[X] Cigarette lighter from junk yard
[X] Cut hole in lift gate panel , get
new 1 from the junk yard [X] Cut off and
Replace Rear liftgate latch handle [X]
Cut off and Replace Rear liftgate latch
[X] Dome light bulb [X] Replace
Drivers seat, junk yard part [X] Engine
restorer [X] Front Side marker bulb
[X] Get console from junk yard and
replace [X] Got 4 floor mats at junk
yard for free [X] Oil and filter changed
[X] Oil filter adapter o rings [X] Rear
Lift gate latch rusted,get lift gate
open [X] Rear end gear oil [X] Rear
side marker bulbs [X] Replace Camshaft
sensor [X] Replace Crankshaft position
sensor [X] Replace Fuel filter [X]
Replace Hood latch cable from junk
yard [X] Replace Horns junk yard part
[X] Replace Spark plugs, spark plug
wires , distributor cap, rotor [X]
Replace dome light cover, junk yard part
[X] Replace thermostat, new [X]
Replace water pump, new [X] Replaced
Stabilizer bar links left and right, new
[X] Replaced left rear bent Axle shaft
bearing and seal, axle junk yard part [X]
Restore headlights , replace left
headlight from junk yard [X] Shift
indicator bulb [X] Turn signal side
light bulb [X] 4new used tires from
crags list, have wheel locks
removed. --------------------------------
-- More repairs done, after the 18 day
period, listed below, Some not listed
yet -----------------------------------
------------- ALL Parts Purchased
And Installed Thus
Far --------------------------
Junk Yard Parts--------- Console R Lift
gate Int, panel Axel Shaft LH Dr
Seat Hood Latch Head Light,Lt Lift Gate
Latch Horns Dome Light Cover Floor
Mats F Drive Shaft 5 Used Tires
, Remove Wheel Locks Mount &
Bal---------------- New Parts,and
repairs ----------- / Air Filter / Turn
Sig Bulbs / Oil adaptor O Rings / Torx
Skt, T55 / Stabl Bar Link Kit / Axel
Bearing / Axel Seal / RTV / Bulbs /
Bulbs / Bulbs / Fuel Filter / Grease /
Gear Oil, 2 / Gear Oil, 2 Repair /
Distributor Cap / Rotor Cap / Spark
Plugs / Plug Wires / Seafoam / Cam Pos
Sensor / Head LT restore Kit / T Stat /
Oil / Oil filter / Antifreeze,2 Gal /
Eng Restore / Water Pump / Torx Skt
T60 / Door Lock Kit / Goop / Dielec.
Grease / Surp. Belt / Radiator Cap /
Harmonic Balancer / Timing Cover Gasket
/ 2
Wheel Bearing Hub Asm. / Crankshaft
Position Sensor / Crankcase Vent Parts /
Oxygen Sensor / Tail Pipe / Headlight
Clips / Steering Damper / Timing Cover
seal / Wiper Blades / Trans fluid /
Brake shoes & pads Fr, RR & park
brake / Brake Rotors Rear / 2 Front U
joints & Ball / Valve Cover Gasket
/ 2 U joints & atf / 2 Ujoints
& Trans Filter / Park Brake Parts /
Steering Wheel Cover / Drain Cock / Door
Latch Lock Jy part / Rekey Lock dr
door / Liftgate Handle / Muffler / Tail
pipe / Oil Fill Cap / (Fluids Changed:Fr
& RR Diff,Transfer
Case Coolant,Oil) / Purchased Trans
Filter & Gasket(not done yet) / Back
Flushed Heater Core / Greased All
Fittings As Of 2-16-2012 / After
2-16-2012 / Replaced Lt & Rt Motor
Mounts / Replaced Trans Mount /
Replaced Rear Control Arm Bushings / 4
New Shocks / Replaced Ignition Coil /
Replaced Ft pas door cladding / Painted
all clading & bumpers Black.
Last problem, 06-05-2012-
-Some times,No start, stalling at idle, stalling rolling at any speed-
-cleaned engine grounds by coil bracket, *FIXED*
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #33 of 46 Old 07-08-2013, 03:36 PM
eagsc7
1994 ZJ
Originally Posted by woodst0ck View Post
I worked at a place called Philmont out in northeast New Mexico. My girlfriend came to visit me, so I made the three hour drive up to Colorado Springs to pick her up from the airport. Somewhere between Eagle Nest and Angel Fire, at around 11 pm (and hour nine of driving), a black bear wandered onto the highway about 15 or so feet in front of me. I was going about 75, and it didn't stand a chance. It was a strange experience, but my zj stayed on the road, kept my girlfriend and safe, and made it up the mountain to Taos. the wreck with the bear didn't kill the engine; that happened the spring before.
So, you Down there this year again? Do you remember Christine S(Lead Ranger) and her ZJ? Its Mine now!
eagsc7 is offline
post #34 of 46 Old 07-08-2013, 03:48 PM
dnuccio
cv driveshaft
rearview mirror
thats really all that ive actually broken. everything else was just general repairs
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #35 of 46 Old 07-08-2013, 08:32 PM
Mickey_D
The only things that I've actually broken on my 3 ZJ's?
I popped a brand new Rock Auto sway bar end link on the white one.
Crushed the tail pipe on the current one.
Pushed the cladding in on the rear door on the green one. It dented the door pretty good, but the cladding covered it.
Those are the only things I've actually broken on my ZJ's. Now, parts that I've replaced? That's a different story...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #36 of 46 Old 07-09-2013, 12:58 AM
970001zj
4 shocks
1 driveshaft ( front )
2 sway links ( passenger side )
4 x exhaust needed re welded
1 radiator
2 thermostats
1 clutch fan ( replaced with t bird fan )
1 v/c ( i can deal with the pops for now )
1 front windshield ( flexing on snow mounds + it had really good heat last winter )
1 climate control system
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #37 of 46 Old 07-09-2013, 03:42 AM
Area11
Drivers Door. Dont ask.
Area11 is offline
post #38 of 46 Old 07-09-2013, 04:08 AM
970001zj
me too , lol forgot to list it
970001zj is offline
post #39 of 46 Old 07-09-2013, 05:47 AM
ZjNightmare
Since December.... I have replaced
Rear hatch
4 lift struts
Window switches
Dimmer switch
Currently replacing the transmission
Shocks all 4
Sway bar end link
There is still a list of things needed to be fixed or replaced. I am convinced my wallet hates my jeep.
Ain't got much but I treat it like Gold
ZjNightmare is offline
post #40 of 46 Old 07-13-2013, 09:35 PM
mrclark25
1994 ZJ
i must ask, but only because i kind of broke mine too.
|_|0|_|
|_|_|0|
|0|0|0|
mrclark25 is offline
post #41 of 46 Old 07-13-2013, 09:40 PM
riot1987
My ZJ has broke MY heart on more than a few occasions.
Build thread^^
riot1987 is offline
post #42 of 46 Old 07-13-2013, 09:41 PM
Area11
The lesson i learned was, Never reverse with the door open.
Area11 is offline
post #43 of 46 Old 07-13-2013, 10:20 PM
riot1987
Did the same thing on the pass rear door.
Build thread^^
riot1987 is offline
post #44 of 46 Old 07-14-2013, 02:39 AM
Area11
Yeah i didnt even change the lock from the original to the one from the Junk Yard. I did get the key to the JY one, it was in the ignition. I still need to figure out the lock motor though. I think i just need to hook something up, i can hear the motor move but the lock doesn't move when the motor does. I have to use the key to get in insead of just using the keyless.
Area11 is offline
post #45 of 46 Old 07-15-2013, 11:36 AM
mrclark25
1994 ZJ
my story is quite a bit different... the door has saged since i got the jeep, and i never did anything about it. because of that, i slammed it one day and the bolts holding the latching mechanism to the inside of the door pulled through the door.
it was an interesting 6 mile drive back home.
picture shows how i fixed it.
|_|0|_|
|_|_|0|
|0|0|0|
