What exhaust tool to remove pipes? - JeepForum.com
post #1 of 7 Old 09-10-2010, 08:37 PM Thread Starter
JLARSJ
Hey all,
What exhaust tool or what is the best method/trick to removing a pipe from inside another pipe after it's been crimped on there?
I used my bushing removal method with a sawsall, but there's has to be something better/faster!!?????
Here was my method but worked
(Muffler was two months old so nearly brand new.)
JLARSJ is offline
post #2 of 7 Old 09-10-2010, 08:57 PM
CrzyMtnMan
Looks like you did a good job, I would just cut (sawsall, cut off wheel, torch) at the crimed seam, remove and replace. Looks like there is still some room to work with on the muffler. Honestly, there are some great exhaust shops where I live that do the work cheap, and offer a great warranty, I let them worry about it on my personal vehicles.
CrzyMtnMan is offline
post #3 of 7 Old 09-10-2010, 10:07 PM
ZJ5point2GCL
what you did, then use a tail pipe expander on an impact to straighten out the muffler
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #4 of 7 Old 09-11-2010, 06:50 AM Thread Starter
JLARSJ
Ok, thanks for the input guys.
The tailpipe expander was a neat little tool, rented one from Advance and worked well.
JLARSJ is offline
post #5 of 7 Old 09-11-2010, 07:51 AM
4Slow9erHybrid
If you use a band clamp like this one
you won't have this problem again.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #6 of 7 Old 09-11-2010, 08:13 AM Thread Starter
JLARSJ
Nice!
JLARSJ is offline
post #7 of 7 Old 09-11-2010, 11:42 AM
bigbossd1030
As previously mentioned, a blowtorch works well in this situation.
When you heat it up real nice, hit it with some oil... right in the open crack where the pipes connect.
If you can manage to do it right (I have only been able to do it once in one try) then it will shock the inner pipe first, then you yank on it.
Again I have only done this once, and I can only guess what happened to cause it to come out so easily.
Must have been my lucky day.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
Tool to remove Power Steering Pump Pulley? A few questions... Jsun ZJ Grand Cherokee Forum 8 07-06-2013 08:00 PM
Easiest way to remove an exhaust gmp211 ZJ Grand Cherokee Forum 5 08-21-2009 01:52 PM
Mandrel Bent exhaust pipes CALO93 WK Grand Cherokee & XK Commander Forum 4 05-20-2009 09:26 PM
4.0L: header questions including tips on how to remove exhaust manifold MEinSoCal ZJ Grand Cherokee Forum 9 07-28-2008 07:06 PM
A/C Pipes are Hot! chris7874 ZJ Grand Cherokee Forum 3 06-19-2006 05:31 PM
