What else should I do while 4.0 tore apart? - JeepForum.com
post #1 of 9 Old 06-27-2013, 08:47 PM Thread Starter
JBrady5555
Hello all I was planning on doing a freeze plug job tomorrow but no where in town has them in stock so I have to order them in. This gives me a little time to think about what else I may want to do to the truck while its tore apart. I just bought the 1997 2wd with 162,000 miles. I don't know anything about the history but it seems to run well with the exception of a leaky valve cover and a really bad leaking freeze plug. Here is what my original plan was:
Replace the 5 freeze plugs on the side of the block
Replace the Intake and Exhaust manifold gaskets since they have to be removed for the freeze plug job.
Replace water pump since its cheap and it may also be leaking coolant.
Replace valve cover gasket
Replace belt.
I've already replaced the oil and filter with Rotella T-5 10w-30 and a motorcraft fl1a. I haven't serviced the tranny yet but its shifting really smooth as is. What else might I want to service while the intake and exhaust manifolds are off? What else should be looked at with a used ZJ when you don't know the vehicles history? I am planning on taking this truck on the road, 500 miles or less trips and I want to get it in good shape. Also I'm gonna coat the back of the freeze plugs with rtv per Oldfrogs recommendation, should any of the other three gaskets that I'm going to replace get rtv? Thanks for any info guys.
JBrady5555 is offline
post #2 of 9 Old 06-27-2013, 09:17 PM
ZeeJay1997
Inspect the exhaust manifold for cracks, If its original equipment it is probably cracked at the collector and / or near the head.
The rear crank case vent is tricky to remove without breaking. It has to come off to remove the valve cover. Be prepared to replace it. Its a metered orifice.
ZeeJay1997 is offline
post #3 of 9 Old 06-27-2013, 09:25 PM Thread Starter
JBrady5555
Yea I need to get that exhaust figured out, its pretty loud and vibrates the truck alot. Not a good kind of loud but broken exhaust loud. I tried to check autozone.com for the crankcase vent but I didn't see it, would it be called something else?
post #4 of 9 Old 06-27-2013, 09:41 PM
dnuccio
PCV valve. stands for positive crankcase ventilation
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 9 Old 06-27-2013, 09:49 PM
ZeeJay1997
give them the OEM part number. 53030495
post #6 of 9 Old 06-27-2013, 09:54 PM Thread Starter
JBrady5555
Thanks
post #7 of 9 Old 06-28-2013, 04:11 AM
AVR2
FWIW, the 4.0L uses a single common gasket for the intake and exhaust manifolds.
You might want to give the throttle body and IAC valve a clean while you have the intake manifold off, and you might also consider the fuel injector upgrade.
One piece of advice I can give you is to slightly modify the FSM pattern for re-torquing the manifold bolts. If you do it the FSM way, the first thing you torque is the exhaust manifold nut nearest the front of the engine, and the last thing you torque is the same nut at the firewall end. That final nut is impossible to get a torque wrench onto with the intake in the way reducing access to almost nothing.
Instead, torque the firewall-end nut first, before you put the intake back on, and do the nut at the front of the engine last. Then it's easy.
AVR2 is offline
post #8 of 9 Old 06-28-2013, 11:26 AM
rooster51
If your removing all that, it only makes sense to install 99+ intake, 62mm throttle body& headers. At least.
Terry
rooster51 is offline
post #9 of 9 Old 06-28-2013, 05:21 PM Thread Starter
JBrady5555
I would if I had the cash, lol. I'm gonna start a new thread with some pictures and questions. I got most of the way through the tear down, but freeze plugs and gaskets wont be at autozone til the morning.
