08-10-2012, 12:29 AM
#1
What does this wire connect to under the hood of my ZJ?
Its never been connected to anything... just hangs there. I have a 95 Jeep Grand Cherokee Laredo 5.2l v8. Picture of wire connector below:
08-10-2012, 01:01 AM
#2
I just noticed that connector on mine the other day and meant to ask about it, too. My hand to the good book!! We swearesss!!
08-10-2012, 01:08 AM
#3
Yea I'm REALLY CURIOUS. Have thought about it a while too and its pissing me off... lol. I was thinking possibly the optional fog lights? do you have fog lights? some ZJ's do
08-10-2012, 01:26 AM
#4
Purge solenoid connection for 4.0L
Mounted near TB on 5.2L
08-10-2012, 01:48 AM
#5
That has to be it, although I have the connector in the exact same place as OregonUSA52LV8 on both of my 5.2's. The same number of pins and the same red weatherpak connector. I thought perhaps it was for the optional motorized headlight tilt system in exports or something along those lines.
08-10-2012, 01:49 AM
#6
so its a 4.0 connector just chilling, even though my purge solenoid is already plugged in near throttle body on my 5.2 anyhow...?
08-10-2012, 01:52 AM
#7
Or maybe (I know there's not one but anyhoo) an airbox inlet temp sensor.
08-10-2012, 01:53 AM
#8
Originally Posted by OregonUSA52LV8
so its a 4.0 connector just chilling, even though my purge solenoid is already plugged in near throttle body anyhow...?
4.0 and 5.2 use different connectors.
Then if the harness is common, there should be a loose connector somewhere on the 4.0
08-10-2012, 01:55 AM
#9
On your loose connector... wire colors DB and PK/BK ?
08-10-2012, 01:56 AM
#10
I noticed that that type of connector is used all through out my 1995's 5.2l motor as well. was thinking it could be the fog light option? what do you think?
08-10-2012, 02:05 AM
#11
check it out (bottom of page on link below):
http://www.jeepforum.com/forum/f13/z...75/index6.html
Fog lights have same connectors as well. but usually located on passenger side they say. interesting
08-10-2012, 02:06 AM
#12
I will check mine in the morning for colors.
@ Oregon - If I recall, the single pigtail for the factory fogs was infront of the a/c condenser off to the pass side if I remember correctly. There was a harness that plugged into it and then branched out to each of the two fogs right infront of the grill.
08-10-2012, 07:17 AM
#13
Nevermind
08-10-2012, 01:24 PM
#14
Light blue and Dark Purple
08-10-2012, 10:20 PM
#15
Yea that's what I heard as well. So you dont have fog lights on your model?
