what does this plug into? - JeepForum.com
post #1 of 4 Old 10-14-2013, 07:09 PM Thread Starter
Turdbasket
1995 XJ Cherokee
I have a 95 grand cherokee with a 4.0. I removed the heat shield under the steering column and found this blue thick wire with several pins (see pic) not plugged into anything. And i can't seem to find an empty spot where it goes. Anyone know what it does and where it plugs in?
Turdbasket is offline
post #2 of 4 Old 10-14-2013, 07:18 PM
joe19934
I could be wrong but it looks like it possibly was a cable used to hookup an external CD player/changer.
If you trace it back maybe you can figure out where it was installed.
I'm guessing it was mounted in the rear somewhere - Either you leave it be as it wont hurt anything or remove if it bothers you.
If You can't Go Around It then Go Over It !!!!!!!!!
joe19934 is offline
post #3 of 4 Old 10-14-2013, 07:48 PM
zjosh93
Looks to me like a previous owner had to get a Breathalyzer ignition interlock.
zjosh93 is offline
post #4 of 4 Old 10-15-2013, 05:45 AM
tucsonzj
my guess
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
