what does it mean if my rear end blew out? help please - JeepForum.com
post #1 of 12 Old 03-02-2005, 06:51 PM Thread Starter
208k
ok i have a 93 jeep with 125k on it. i was driving on the interstate the other day and a bunch of smoke started comming out the back of the car. i saw it when i looked in the mirror. it made a big noice and i pulled over and looked at the back of the car. there was what appeared to be oil all over the back and there was smoke that looked like it was comming from the axle. when i took it in, they said it was the rear end. what does this mean? they said it blew out. now before this happened, i noticed that the v8 was not giving a lot of power. i just got the car so i dont know if its normal power or not. cold this rearend have anything to do with the bad power? what else should they replace when they put a new rear end on? i know nothing about this. as much info as you could give would be helpful. thanks
208k is offline
post #2 of 12 Old 03-02-2005, 07:08 PM
Ned97sahara
I blew the rear in my 97 TJ last year. I shattered my ring gear and chipped some of the spider gears. I don't know what it could be in your case. If you have the trac lok in it that may have failed. Or you could have been low on fluid in the diff and caused it to over heat and fail. I'm sorry if I couldn't help you the way you wanted. Good luck
2007 Ford Ranger 4x4 4.0L auto ( I know it's not a jeep but untill I buy my wife a house this is all I am going to have) Future mods: AEV bridgers and some 32's:)
1st jeep:98 TJ sport w/4 inch lift and 33's (wrecked)
2nd jeep:97 TJ sahara locked and loaded w/7" of lift and 35's (sold for WJ)
3rd jeep:2004 grand cherokee WJ special edition
W/MTR 245/75/R16's (sold for 07 Ranger)
Ned97sahara is offline
post #3 of 12 Old 03-02-2005, 07:13 PM Thread Starter
208k
sweet does it run ok now? any other problems?
208k is offline
post #4 of 12 Old 03-02-2005, 07:18 PM Thread Starter
208k
also, do u know how much it cost to fix that?
208k is offline
post #5 of 12 Old 03-02-2005, 07:38 PM
cajunmudder
cajunmudder's Avatar
Yeah my diff is leaking fluid out its gasket now and is hummin like -=-=-=-= but I'm tryin to blow it so I can get a locker or posi But you will most likely have to replace the whole differential, and it will run normal again.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
cajunmudder is offline
post #6 of 12 Old 03-03-2005, 10:34 AM
Myrtle Beach
I think it means you ate too much
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Myrtle Beach is offline
post #7 of 12 Old 03-03-2005, 12:04 PM
7thStranger
7thStranger's Avatar
the pumkin lookin thing on your rear axle has gears in it. They went bye bye.
98 Grand Cherokee I6
7thStranger is offline
post #8 of 12 Old 03-03-2005, 12:08 PM
PumaZJ
dude if you do that you're gonna hafta buy all new gears, bearings, seals and have it all setup with the locker in it costing well over $1000. Why not just keep the flud IN it, buy a locker for $200 and install it yourself?
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #9 of 12 Old 03-03-2005, 04:29 PM
cajunmudder
Yeah it was a joke....I got a bottle of 90 weight today.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
post #10 of 12 Old 03-03-2005, 06:35 PM
CaliforniaJeep
CaliforniaJeep's Avatar
Originally Posted by 208k
... i just got the car so i dont know if its normal power or not...
Never call a Jeep a car Could always upgrade your gears if you wanted too!
-Johnny-
~Updating~
CaliforniaJeep is offline
post #11 of 12 Old 03-04-2005, 09:46 AM
2Grand4s
125 K and Rear Goes ?
My 94 has the original and over 200K, admittedly it needs a new gear or two since its starting to humm. That's a tune meant to warn me. My guess is either you ran out of fluid due to a leaky gasket, or the previous owner never changed the stuff. You will need to check all the wheel bearings on the rear axle, and check the drive axles themselves for damage. The Differential is in need of replacement. If you intend to keep this Jeep, get a Trac-Lok (aka Limited Slip) unit and replace the one that's morphed into scrap metal. That way the wheel that is not spinning in the mud gets the power, and you get to move forward.
Ed . . .owner of 2 Grand's, a 94 Limited V-8 w/Up-Country and a '04 Overland 4WD
205,000 miles on the '94, 2500 Miles on the '04
2Grand4s is offline
post #12 of 12 Old 03-05-2005, 07:27 AM
Ned97sahara
Well when I blew the rear in the TJ I had luckily bought a ford 8.8 a few months before it happened just wasn't ready to put it in at the time but was forced to. After the 8.8 install it worked great ran good until this past january when I got rid of it to get my WJ. My engine was very weak and there was something wrong with my T-case. I just found out two days ago that the dealership that I traded it to said the engine was shot, the tranny was going and the T-case was binding and the chain was about ready to snap. They unloaded it to a auction.
rear pinion blew out now what???? drob951 ZJ Grand Cherokee Forum 2 08-01-2009 05:37 PM
rear end blew up... AGAIN dmolaver15 ZJ Grand Cherokee Forum 18 02-25-2009 11:08 PM
Blew another tcase rear seal. need some input fast BLACKzj52 ZJ Grand Cherokee Forum 20 01-31-2009 12:43 PM
Blew Rear speaker... what can I replace it with?? bigtb ZJ Grand Cherokee Forum 3 06-19-2007 02:04 AM
Blew a rod! mattklaman ZJ Grand Cherokee Forum 10 07-17-2004 10:03 PM
