What does code check engine code 14 mean?? - JeepForum.com
post #1 of 2 Old 10-19-2010, 08:58 AM Thread Starter
tawa1075
1994 ZJ
My check engine light came on and I did the key flip thing to get the code and I got 14. I read either the map sensor is reading too high or too low. Anybody have any info? THank you
tawa1075 is offline
post #2 of 2 Old 10-19-2010, 03:54 PM
rm2001wj
rm2001wj's Avatar
It means that the MAP sensor is not getting the 5 volts from the PCM that it needs to operate correctly. Unplug the wiring harness from the sensor. Connect a voltmeter to the two outside terminals of the plug and then turn the ignition key to the "on" position. If the meter reads about 5 volts, then the problem is in the MAP sensor. BTW, the middle terminal is the one carrying the MAP sensor signal back to the PCM.
If the voltage is not correct, then there is a problem with the the plug or wires or PCM. One of those two outside terminals (I don't know which one) is connected to ground. With the ignition "off", use an ohmmeter and check the resistance between each outside plug terminal and a ground somewhere in the engine compartment. The terminal with zero resistance is the ground terminal and the other is the 5 volt terminal. It's the 5 volt terminal and wire that you have to worry about. If it turns out that neither wire shows zero resistance with respect to ground, then the ground wire and terminal is most likely the problem.
rm2001wj is offline
Check engine Code 31 john96zj ZJ Grand Cherokee Forum 0 10-01-2009 07:47 AM
Check Engine Code 43 and 27 JEEPOLD ZJ Grand Cherokee Forum 2 02-04-2009 09:43 AM
Check Engine Code 31 ????? Anybody..? SpeedyCat3 ZJ Grand Cherokee Forum 2 05-14-2007 05:30 PM
check engine code 51, what to do? octopi ZJ Grand Cherokee Forum 1 12-27-2006 10:04 PM
check engine code? libertyRubicon ZJ Grand Cherokee Forum 4 07-06-2006 03:02 PM
